I've been running a Wilwood clutch master for a while now--GS Compact Integral Master Cylinder, PN 260-15098. Still using the same long-throw slave I've had in the car since 2009 (Amazing that it's lasted this long). The Wilwood clutch master works just fine, but after a couple of failures (fewer than the many "OEM" masters I went through), I may go to a Tilton clutch master for basically the same reason this guy determined when comparing the two... https://youtu.be/Hz4AlAt7DJ8
Wilwood Clutch Master
  • Wilwood Clutch Master
Yes it’s a McLeod from Pantera Performance and they supplied the throw out bearing. I’m running a Coyote. Strange that the pedal has gotten so stiff intermittently… sometimes fine and sometimes it’s terrible…. On the way home today, it decided not to let me put it in gear, but then after depressing it about five or six times it did and then I drove home pretty normally, but with a really stiff clutch.
FWIW, I installed the PIM McLeod clutch, pressure plate and throw out bearing system in 2017. It was MUCH stiffer than the old, slipping, non-Pantera clutch I replaced, but the stiffness of the new clutch  was never intermittent. So, I installed an Effort Reduction Kit a few months later, and the difference was noticeable. It was either that, or I was going to have to go to the gym to build up the strength of my left leg.
Also thought I would add why I had to change my clutch after 1500 miles. One of the cast fingers on the diaphragm broke off. I’m not sure how long it was broken off and rattling around in there, but I really did love the clutch. It worked perfectly with the stock slave cylinder. Here are some pictures for your enjoyment. The frustrating part was that they didn’t warranty it, so that’s why I decided to use a different clutch to see how that worked🥴.  One day I pushed in the clutch, and it didn’t disengage… Could not figure out why… If you look really closely, you can see that the finger spring lodged itself perfectly in the bottomIMG_7051IMG_7054
Images (2)
  • IMG_7056
  • IMG_7054
I'm running the Mcleod clutch and throw out bearing carrier as well as the Wilwood 0.75" master cylinder.  I've tried both stock and long throw slave cylinders but still have a hard to push clutch pedal.
I pulled the ZF last month to check everything out.  I found the fork inside the ZF that engages the throw out carrier was wearing unevenly.  This caused the carrier to slightly twist and was uneven along the travel on input shaft.  This caused some binding/resistance in the middle of the travel which created galling on input shaft.  Notice the fork finger on the left is worn down and was making less contact with the carrier bearing.   It took me a while of studying the travel with the ZF out of the car.
I cleaned everything best I could at it is improved but still stiff.  I think the solution is to replace the input shaft and fork assembly but I'm saving that for another time.
John
#3590
Images (2)
  • mceclip0
  • mceclip1
@rlee63a4 posted:
I had a similar experience  when I installed a McLeod clutch, pressure plate, and throwout bearing on a 72 Pre L.  Substantial effort was needed to press the clutch pedal.  My solution was to add the clutch effort reduction kit, the one with needle bearings.  The clutch was easy to operate after that change.
My kit did not come with a pushrod for the master cylinder.  I can't recall exactly what I did to make it work but it was not a big deal to achieve the correct length.
It is a bit of a project to add the clutch effort reduction setup.  You have to pull the pedal box and press in a longer shaft that is shared by the gas pedal and the new clutch pivot.
Be sure to check if you already have it.  If it's already there then it is likely worn out.  It is much less of a project to fix the worn pivot because you are just replacing parts.  You might be able to do it without pulling the pedal box.
If you use the stock cast iron bearing carrier it has graphite in it and will help alleviate the problem. Yours is the fourth one that has had this issue and they all used the McLeod steel bearing carrier. One suggestion I have if using the steel carrier is to have it's inner surface coated with an anti friction coating.
@rlee63a4 posted:
Did you end up getting the Tilton? I'm looking myself
I bought a Tilton to have on the shelf for whenever the Wilwood fails...again. Actually, I think I have a Wilwood rebuild kit in stock.  So, I'll most likely rebuild the Wilwood master before moving to the Tilton. I hope to minimize the pain and time spent working under the dash. Although, I've almost got the clutch master R&R down to a science...
@rlee63a4 posted:
Which Tilton model did you buy?
@rj posted:
Tilton 3/4" master cylinder kit 75-750U. I didn't need the remote stuff, but I wanted the small reservoir that comes in the kit. Buying the kit was easier than trying to find and buy individual components. Should work just fine and be a similar installation as the Wilwood with the same minor mods and adapters, but only time will tell...
