Does anybody know if this will fit?
Since you appear to be starting from scratch, please read this thread.
http://tinyurl.com/duraspark
Ford spent a ton of money developing this, parts are at every auto parts store, on the shelf (not special order) in the whole country, and it works fine.
Jack DeRyke (Bosswrench) posted this recently on the POCA forum:
Agree. I don't even know what color strain relief I now run on ours after
leving the key On for too long and blowing the brainbox. Whatever Kragens
sells as a Duraspark 2 for a 460. I also heartily recommend running a later
model E-coil on the recommendation of JC Christian, rather than the can of oil
type coils- which went south with the box. I did find a variation in
mounting bolt hole position, but changing one hole out of 3 in the Pantera mount
plate is not a deal-breaker around here. FWIW- J DeRyke
I have read of plenty of MSD and Mallory failures. And replacing failed parts is $$$ and takes time to receive.
KISS
