I have moved into a condo, I have zero room to rebuild my engine, can anyone suggest a engine builder who can static run the completed engine and also dyno it on the central coast of ca.??? The engine was done by a old friend ( famous racer) who passed away shortly after he put together the current engine, it has a number of major oil leaks and must come out.
Originally posted by pantera chris:
I have rebuilt the engine before and could do it again, but, I have really no space to work on it and the environment is unclean, beach, sand, that said the motor is dynoing at 497 H.P. it is a race more than street engine and I want to up the numbers.
500hp is around the limitations of the car. Looking for more is not exactly just a rebuild either.
Simplest way is just to put a stroker kit in it. Having said that though, 427 of anything is no longer what is commonly refereed to as a small block.
The characteristics of the car are very different then.
Going that route is just starting the hour glass on a very expensive ZF rebuild. When, who knows, but eventually and then periodically from then on.
Chris
I'm not aware of anyone on the Central coast.
The closest shop I could refer you to at this time would be Jim Grubbs Racing in Valencia. Russ Fulps has served the Pantera community well, although I haven't met him in person, he seems to be a man of integrity.
I live in a condo too. I understand the transition you're going through. I found a storage unit in the Ventura Marina that meets my needs, it replaced my garage. But I have to abide by their hours. Best wishes with your transition.
-G
Thanks George, hope to incorporate some of your incites, your knowledge on the car amazes even me.
Originally posted by George P:
Chris
-G
