I've always been a Castrol guy, but was put in a position that I was recommending Shell Rotella because it had the ZDDP and was available in single viscosity 30 weight grade. Now that diesel engine oils have been reformulated I'm recommending (and will start using myself) Valvoline VR1 racing oil. It is available in single viscosity 30 weight and has plenty of ZDDP in it.
If you're wondering why I specify single viscosity oil, it's because the oil manufacturers use a base oil with a more shear resistant molecule in their single viscosity grades. You'll notice the straight 30 weight oil available from most manufacturers says "HD" (heavy duty) on the bottle.
Valvoline VR1 says "for racing only" on the bottle, so hopefully nobody will mess with it's formula for a long while. VR1 is readily available, so there's no reason to stock pile diesel oil in your garage.
cowboy from hell
