quote:If things get too wild, you can always take the tie-wrap off....
Good idea but I don't see that happening. Maybe if I let anyone else drive the car.
![Big Grin](/static/images/graemlins/icon_biggrin.gif)
quote:I am going to have to go do some 0-60 and 1/4 mile runs to see where we are
quote:Where is this ending?
quote:Will you market a kit so others can do the same as you?
quote:Or is it too much of a hassle to do, sometimes one finds during a customization like that that it's not worth all the effort?
quote:The mpg is not that important to me, don't drive it daily, but the drivability, the 100k+ miles lifespan and the peace of mind driving it on long trips would be great
quote:just from a google search, I found mention that the blow bypass valve was vacuum operated.
with high manifold vacuum (and boost not needed) the butterfly opens and reduces the parisitic load of an useless blower.
with loss of manifold vacuum (accelerating or high power demand) the butterfly closes.
maybe just disconnecting the vacuum hose would do the same as the tie wraps, but it sounds like a feature you would want
please note this is just keyboard mechanic/engineering as I an humbled by your work
quote:Maybe, just like with our cars, it's the journey, rather than the destination?
quote:I checked out the CNC Performance shifter, which has a link to SACC, but can't seem to find it on your website. Can you post a link?
quote:This is what Ford gets for discontinuing development of pushrod engines.....
I may have spoken to you a couple if years ago. I asked if you had very good traction and you said that you did not have any! You need the new C8 transmission, the eighth wonder of the world. Chevrolet engines consistantly throughout the years are smaller, lighter and less expensive than Fords. And, the hurtful thing, more powerful.
I love it, I have been driving the only LT79 powered Mangusta since 1979, built at the factory.
DICK RUZZIN
@italford posted:how about an LS3 in a pre 75 Toyota truck. Tubbed of course LOLn
good luck with your ls swap.but its a sad day in the pantera community you dont deserve such car.
You guys are hashing up a two year old debate. I think this thread has played itself out unless Scott wishes to add an update etc.
I think an LS9, properly swapped into a Pantera (as I know this one is) would be AMAZING!
