Looking for an original Pantera lug wrench.
Thanks Mike
Thanks Mike
Can't help you there, Mike as I've never seen one for sale. Possibly, a junkyard will supply a similar wrench that can be sawed to length, heated & bent, then painted to look like a Pantera wrench. But I caution you and others NOT to use the short jack-extension as a lug wrench with a ratchet. It's unfortunate that the hex size for the jack extension is coincidentally the same size as the lug nut hex. Because the jack extension is unhardened and will split the hex if used there!
A split jack extension can be rewelded, dressed smooth and re-alodined gold, and can then be safely used again for its designed purpose or for shows, but it cannot ever be used to tighten or remove lug nuts! I've fixed one for another owner plus one of my own.... Same goes for the much longer telescoping extension for the Mangusta, I believe.
Im just trying to put together a tool kit. I would never use any of those cheap tools.
Yeah I'm watching......
Still looking for an original Pantera lug wrench.....
Mike- that tool you showed should NOT be used as a wheel lug wrench! It was designed as a jacking extension only. The tool is unhardened mild steel and the internal hex will split if torqued to what wheel lugs need. Other models of Italian cars use the same design jack and extension (several slightly different lengths), and have the same splitting problem if by coincidence the tool's hex matches the lug nut size.
Fortunately because its only mild steel, cracked extensions can be gas or arc welded (being careful to not melt the plastic hand knob), filed flat, then re-gold-alodined to look & function as-stock as a jack extension. I've repaired maybe half a dozen so mistreated. One was split in 3 places- apparently owned by a slow learner!
Look in the red Owners Manual or the Tech Service Bulletins for an illustration of the actual stock lug wrench- its a long tin socket with a simple steel crossbar inserted thru drillings. No one ever uses them; in fact they're often thrown away. Carry a real lug wrench & use the stock stuff only for car shows.
