Mr. Dick Ruzzin forwarded this advice on ball joints for the Mangusta:
My message is for Mangusta owners who may not know that the upper front ball
joints do not have a grease fitting and can eventually break from lack of
lubrication. Just before that happens the steering gets very hard.
This happened to a friend of mine, Herb Grass, who purchased a car that had
belonged to Cassias Clay. Two weeks after he bought it he had the problem.
I tell this to everyone that I meet who has a Mangusta.
1. To correct the problem, remove the front wheels.
2. The upper a-arms are held to the upper ball joints by three small bolts.
3. Remove them and the upper a-arm can be easily raised exposing the top of
the ball joint that has a drilled and threaded hole in it.
4. Screw in a grease fitting and grease it. Maybe for the first time ever.
5. Reinstall the upper a-arm after removing the grease fitting and you are
all set for a while.
I went another step, as follows:
6. Drill a hole in the upper a-arm cup at the outer end of the a-arm between
the three small bolt holes that is large enough in diameter to allow
installation of an extended grease fitting. This can be screwed directly into
the ball joint using the provided previously mentioned threaded hole. Bolt
the a-arm back together and install the grease fitting through the new hole.
Then you do not have to take the upper a-arm off the ball joint to grease it.
Dick Ruzzin
Great post!
Grease was not an issue when I pulled mine apart, I found them all in bits. Welds were all busted and metal parts were in pieces. I detailed this all in a POCA article earlier this year, just prior to Vegas.
Rather than risk it, cracked welds and metal etc, just replace the ball joints! Same as used on a Fiat 124. They have two sizes, and as I recall, this is the larger of the two, just that DeT used them both the same size and not different top to bottom like Fiat... I don't think the new ones are greasable, but you can lift the boot and put more in!
Should run you about $15 each.
Take care and sorry for the late response!
Steve
