Hello there everyone,
I need some help to resolve a problem with my Mangusta 646. Yesterday during a ride my clutch pedal snapped and the clutch did not work anymore. Once rescued the car in my mechanic shop we found that the pin that is pushed by the slave cylinder broke and as well as the slave cylinder that is attached to the engine, at this point I guess I have to detach the all ZF to change the parts... Anyone have any idea where I can find the pieces? I live, as you know, in Italy... Once I pull out the ZF I think I should also change the disc clutch and all that can be replaced, do you have some suggestion and advice about it?
Thanks a million in advance for any help...
Best from Italy Paolo
