Originally posted by johnk:
Let me guess, 2 piece valves?
YES!
Originally posted by LF - TP 2511:
...You can still see the FORD logo on the intake valves, so reasonable assumption is the exhaust that let loose is also still stock. Although the good exhaust valve in the first photo shows no logo?...
Larry, the oem exhaust valves don't have the blue oval, they're plain. Just the intakes have the logo.
your friend (and brother) on the DTBB Wink
It happenned to me with my first 351C that I swapped into a '66 Mustang
fastback. A couple of hours on rebuild (standard bore block, flat top
pistons, 0.550" lift cam, stock Ford valves), it popped the head of the
valve off the stem. The stem stayed in the guide but I pulled the
valve head out of the exhaust header. Heard a bang under the hood,
stopped and lifted the hood to see a fist sized hole gushing coolant
and oil out. The valve head bounced around until it shattered the piston
then the rod poked it's way outside. Notice the nice beam polished rod.
http://www.bacomatic.org/gallery/album16
Destroyed the block, a head, the cam, lifters, rods and more.
Dan Jones
