Been taking inventory and havent been able to locate new screws for the door striker and door alignment cup.  I have scoured posts. I ordered replacements but they don't recess flush. Can anyone help?
(4), 8x30. 1.25. (13.5 phillips head).
20190217_165658-COLLAGE
(4) Phillips screws 6mm 1.0. 20mm (11.8-12 head)
20190217_164706-COLLAGE
Images (2)
  • 20190217_164706-COLLAGE
  • 20190217_165658-COLLAGE
An electric drill and a std. countersink will put the screw heads wherever you want them but will also remove any plating on the striker. Note there's a LOT of room (relatively) between the door surface and the striker plate surface. Use modeling clay or multiple layers of masking tape to reassure yourself that a few thousandths of screw-head protrusion will not scratch up your door(s). Pantera bodies are NOT machined-to-perfection weldments.
