OK, Mr.Pence, I give up. I can't find the post about the new fans and relays.
Not that it matters, because I have a print out of the diagram to wire them in.
The problem is that the diagram says "new fuses" on the wires to the 86 terminals.
In my finite wisdom I could find no references to what size.
I would presume that I should use two of the sizes already in use in the stock setup?
Also the + electricity goes ^, and - electricity goes V right? That's the difference, right?
