I just finished a new flat panel console for the single pod dash. It gives you the ability to install anything that will fit in any style variation you like. The gauge, switch, and/or screen area in the center is angled towards the driver for better visual direction. I will supply a flat panel insert that is a recessed fit into the center shape which can have custom cut openings in your particular size and shapes. The console will come in various combinations depending upon what you may need.
This one has a smaller right side upper angle because the original heater slide control is not being used. I will post some additional pictures when different versions are built.
If you would like a flat panel console, please drop me a note at amerisport@gmail.com or call at 419-344-8148
Thank you
Kirk
