why a typical 5 or 6 speed transmission won't work
in a mid engine car?
quote:Originally posted by AdvenDriver:
Thanks guys. And I appreciate the support of the ZF. Being so ill-informed on the topic of mid engine cars all the above is very
valuable to me.
quote:I was not intending at all to cast dispersion on the ZF, so if it sounded that way I am sorry, for sure!
quote:I just could not imagine why mechanically, a car could not be built, say using a 1969 Mustang Engine & transmission, connected to the normal differential, just using a universal joint and no shaft, and build the car in a mid-engine format around such a set-up. What I am get-ting here is it would be a LONG car. AM I ON THE MARK? Thank you.
quote:Regarding KE's ZF NO BEARING story, that's pretty darn impressive!
As to the above air craft, a B2 Bomber ancestor I'd call it...![]()
quote:Originally posted by Kirk Evans:
Here is a link to the National Geographic special on the design. http://channel.nationalgeograp...erview#tab-Photos/23 There are stills on the link and the build speical on the model is airing on NGEO channel December 9th at 9PM if anyone is interested.
