Put the car away for the winter and just went to check on it. Started perfectly but clutch pedal went to the floor. Worked perfect when stored.
Checked and reservoir was empty
Are the lines from the master to the slave all plastic? I think it may have cracked in the cold. Any tips running new one and bleeding? Any special tubing needed?
Didn't really have any time to triage but looked like fluid underneath
Thanks in advance
Chip
Originally posted by r mccall:
Pantera East sells a VERY nice Stainless Steel " long throw" slave cylinder.
Ron
I haven't been able to find him in about three years. Mario just disappeared.
As far as I know, the original stock unit is rebuildable but you have to find the parts since I've never seen them assembled in a kit.
The polished stainless is the nice way to go as long as you don't change the size of the the piston bore otherwise you change the effort required on the clutch pedal.
I don't know what he did with that but he must have found the rebuild parts in order to make the stainless units out of stainless billet tubes.
I had my original chromed and the original o-rings still seem ok. They can be sleeved also like the master brake cylinders are now done on irreplaceable originals of other makes.
$45 is a bargain though if it is the same unit and if it is you probably just found the source of them the other vendors get them from?
Just talked to Marino. Alive and well and still selling slave cylinders.
Does anyone know what type of clutch assembly that Wilkinson sells? Marino was asking what type of clutch was in there to determine if I needed a long throw or not.
I just looked in my paperwork that it was purchased at Wilkinson, but there is no description on their website to answer what type
Chip, I suggest using a long throw clutch slave regardless of what clutch is in there. It will give slightly more disengagement distance at the flywheel than stock, and being stainless, it will not rust like the soft iron stockers. It is also rebuildable if something happens to the fragile rubber seal. It's my understanding that Marino had those slaves CAST UP to order, using some domestic guts. It's been 10 or so years and I suspect he's barely recouped his minimum order cost. All the vendors sell Marino's slave cylinders.
You can check clutch disengagement distance with a flat-blade feeler gauge stuck down thru the access window in your bellhousing between flywheel and disc (engine OFF!) A brand new Pantera with new hydraulics and new linkage will allow about 0.040" of disengagement distance (which divides by 2 for each surface of the clutch disc). And that's with the clutch pedal buried in the floor mat, which no one ever does when shifting. Worn systems or leaky ones will be down to 0.015" or so, causing drag and high wear in the ZF synchro system. A long-throw slave will pick up the distance to as high as 0.050"
Its also a good idea to consider ordering a new clutch MASTER cylinder right now: the parts all wear out as a system so fixing leaks and wear at one end often overpressurizes the other. Replace the clutch slave and expect to be fidding with a leaking clutch master cylinder before Christmas.... Good luck.
Originally posted by Chip:
Thanks Jack....Sage advice as always
Hi Chip,
Hey, just a thought......found an old PI Tech Article (Winter, 1977), a VW Transporter Front Wheel Cylinder rebuild kit (1970 or prior) will work on the slave cylinder. RockAuto has a BECK/ARNLEY Part # 0717331 kit for $2.73, or a RAYBESTOS Part # WK362 professional grade for $5.31. If your old slave can be rebuilt, keep it as a back-up.
Pete C. (6626)
I was under the impression a "long throw" has a slightly(?) smaller inner diameter, giving more travel, and increasing pedal effort slightly(?).
Here's an old Post...
fordgt
posted October 19, 2001 05:53 AM
I replaced my standard throw with a long throw recently. The inside diameter of the standard throw is 0.991 inches and the long throw measures 0.866 inches.
FWIW, home-repair of a stock clutch slave is usually wasted effort. True, there are repair kits made for several other cars that can be adapted to sort-of-fit the Pantera. But the relief is often short-lived. First, the design is extremely simple with one seal which doesn't have much tolerance. So when you home-hone the corrosion pits out, the resulting bore is often bell-mouthed or expanded enough that the adapted seal in a rebuilt cylinder may instantly leak under pressure. I equate this with fine-tuning OEM ignition points: even when done perfectly, you know it won't last. Next, the cast iron used by the factory in our slave cylinders seems particularly soft and corrosion-prone. Some guys have found rust inside the bore of brand new cylinders still in a factory box.
The pitting and leaks normally happen due to NOT changing clutch (and brake!) hydraulic fluid yearly- maybe biannually in coastal areas. And its been found that using silicone fluid does not cure the collection of water inside the cylinders, either. Unless the hydraulic fluid is changed regularly, brand-new pits will develop rapidly in new-stock or repaired-stock ass'ys. Corrosion-resistant stainless steel or hard-anodized aluminum master & slave sets cheaply compensate for our poor maintenence habits- mine included.
