I'm fairly sure that the inlet to a stock slave cyl is 12x1.25mm. If that's how the stock hose is threaded, it must have screwed directly into the end of the slave, possibly with a copper seal ring(?). In not, what kind of fitting or adaptor is used there?
Same question for the other end of the hose - what are the threads and how is the connection to the copper hard line accomplished?
Anybody have photos of these details? Specs on the OEM hose would be fantastic as well, especially length and end fittings.
Thanks for any help, it would be REAL nice to hammer out this detail and move on to the something else, hopefully not in the hydraulics dept
