Can anyone recognize this oil pan & size? It feeds my 427. I would suspect it is 10 qt. I put in 8&1/2 qt and it fills way beyond the full point on the stick, but I am figuring stick and pan don't jive.
quote:Originally posted by LIV1S:
Sorry, I took a closer look at yours and the back end where the relief is for the xmember, looks looks stock. Hall used to sell one like it which was essentially a stock pan that was cut and an extended sheetmetal welded up. I don't remember how many quarts it was rated for though.
quote:Originally posted by Dave2811:
Ultimately, it is irrelevant what the pan capacity is. You are going to fill it according to the dipstick, assuming your stick is the correct dimension (38" from the hilt to the tip). Maybe double check it against another car.
Filling to the dipstick full mark, assures that the pickup won't ventilate. It is the dimensional relationship of the stick to the bottom of the pickup that is important, regardless of pan capacity.
quote:Originally posted by DOES 200:quote:Originally posted by Dave2811:
Yeah, but I assume everything is modified, same as my red 5S with the 417 Fontana. Dip stick tube could have been modified as well, who the heck knows. I did notice on my red car that it has the same oil pan, and I see past receipts where they did 10qt, so I can probably assume these are 10qt (if they knew what they were doing).
quote:Originally posted by PanteraDoug:
You fill it according to the calibrated dip stick. Whatever the system takes is it. My system takes about 12 qts. with the oil cooler , aviad pan, remote duel cartridge filters and the -10 hose to plumb it all but it ain't full till the fat lady sings...and it says full on the dip stick.![]()
quote:To settle it for all of you that have bought an Armando pan; when AVIAID designed that pan the static oil capacity of the pan was set at 9 quarts. That fills the pan to the underside of the hard tray that is bolted in on top of the pickup box assembly in the pan. Our instructions for actual capacity determination are to fill an empty pan, installed on the engine in a car sitting on flat ground, with 8qts. of oil. Mark your dipstick. Add one additional quart, and mark the stick again. This is full. The first mark is the low mark. This should be only about 3/8" given the sump area of the pan.
Start the engine, letting oil circulate and fill the engine, filter and any cooler or lines that may be part of the system. Shut the engine off, and add back to the top mark. This will be system capacity.
Depending on engine and operating conditions the ideal level can vary. Ideal oil level is a point between fluctuating oil pressure and excess carry over of oil out of the engine venting system. If the engine tends to trap oil up in the engine, it will like an extra 1/2 quart. If the engine returns oil well, it might like 1/2 quart low. Experience will tell.
John Schwarz
AVIAID Oil Systems
10041 Canoga Avenue
Chatsworth CA 91311-3004
00 1 818 998 8991 phone
00 1 818 998 8993 fax
aviaid at aol.com email
aviaid.com web
... When I get under the lift I will see if there is some way of getting at the tube connection to the pan.
It is most easily accessed from inside the front engine cover. The tube stabs into the block just behind the alternator. It doesn't touch the pan at all.
Ugh, I will need to see how easy or not that bulkhead is to remove from my interior set up. Doesn't sound like fun in this stinkin hot and humid weather in the garage. If the stick goes into the block, I wonder if it is the same on a Fontana block. What the heck rusts anyway, the top of the tube or the stick or both?
