All things- even precision bearings & axles- have tolerances. And with press fits, the assembly requirements are in the ten-thousandths of an inch range. A proper pressfit on axles is 0.0005" to 0.0008" larger than the bearings for that assembly. One simply cannot check this with a std calipers. I use extreme-pressure rear end lube or Lubriplate moly-grease on axles when pressing, and for really tight fits, its well to freeze the axle and heat the bearing to about 150F degrees before pressing.
The only thing I can think of for your lock-up problem is, the extreme press pressure bent the outer steel bearing retainer, and there's not much clearance between that retainer and the wheel-stud heads. Likely, the torque wrench was still trying to pull the nut down tight so it didn't 'click'; 300 ft-lbs is not enough torque. Around 450 ft-lbs is more realistic and is why one uses new nuts if they are the sliced ones that twist when tightened. Filing the scratches flat (but not out completely) on the scored new axle will work fine, as will selectively fitting a new bearing to the 'tight' axle. You may find a new bearing that FALLS ON- that obviously is on the other end of the tolerance scale! One thing with a press: do NOT use simple stand-offs on the brake rotor to back up the pressing: you will shatter the disc- as your mechanic found. I use a huge steel pipe cap 6" thick with a hole bored thru that just clears the axle flange and contacts the rotor on its curved edge, not on the braking surface. Others use wood or plastic stand-offs made the same way. I know of several owners- including vendors- that have broken cat iron brake rotors trying to disassemble.
Finally, drive or press out all 5 wheel studs before pressing an axle in or out; this removes about half the pressure required to assemble/disassemble a properly sized Pantera rear suspension.
Vented rotors will stabilize on a hard-driven Pantera about 200F degrees lower than solid rotors, so if your driving will be at Bathurst or other such, you'll need vented rotors on both ends and Porterfield R-4S brake pads, to keep from brake fade- especially with the deeply-embedded brakes on a GT5-S! On streets & highways with only occasional stops, either rotor will work fine. Hang in there- this WILL go together.
Thanks Jack.
I actually tried to do it right. I found a length of 195mm ID steel pipe and parted a length off so that it would support the entire way around the rotor, but I was right on the edge of the braking face, so the 'top hat' section was captive inside my pipe.
Hard to say what they did, but maybe it was crooked or something? Now I just need to find new rotors and move on.
After hours of searching last night it seems that only Wilkinson advertise a 'standard' rotor for my 74 L model. They are not expensive, but I know the shipping will be due to the weight.
Surely somebody has come up with a modification for a slip on rotor for these cars using a common and available rotor?
I thought about it during the night. Purchase a new set of wheel studs with the knurling right at the head like Toyota/Ford use. I'm using Bob's axles so the head of the axle is really thick and would support the studs beautifully. Assemble everything as normal but without the rotor.
Then find a rotor with a deeper top hat section that slips over from the outside and locates on the new studs and also the deep centre flange of Bobs axles.
I had a rear rotor in the shed from an early 90's Lexus SC400. I laid my back wheel down on it's face and then sat the rotor in there and aligned the stud holes by eye. Then I grabbed my new axles and sat it in there. The centre bore of the Toyota rotor was a perfect fit on bobs axle. There was still 10mm of the locating flange sticking through the rotor and this fitted perfectly into my wheel. SO you only have 10mm to locate into the wheel, but many cars only have 6mm anyway.
As the Toyota / Lexus has a small handbrake drum inside the rear rotor, the main body of the axle fitted perfectly in there.
The standard top hat on the solid rotor appears to be 42mm high from the rotor face. Bob's axle heads are 14mm thick. Toyota rotor face is 5.5mm thick.
All one would need to do is some mathmatics to
establish the top hat height required to put the braking face of the rotor in the middle of the caliper and it shouldn't be too tricky to do that.
I just did a quick drawing. Considering rotor is 18mm thick (>???<) and original top hat is 42mm high from the rotor braking face then its 64mm centre of caliper to mounting face for the wheel.
If I used a slip on rotor from any 114.3 PCD 5 stud configuration Japanese or Ford car with an internal rear handbrake (so it will take the axle) then I would need to find a rotor with a 55mm top hat height to maintain the same 64mm to the centre of the caliper from the wheel mounting face, which would now be on the rotor, not the axle.
This would make it so much easier to change rear rotors, never having to go through this hell of dissasembly and trying to find tools to get 400lbs out of that split nut.
I need some clarification on what thickness the standard rotor is as mine are 18mm and used.
What's your thoughts Jack?
  • Pantera_rotor
Has anyone fitted the double row inner wheel bearing conversion?
I purchased these bearings locally and as the new beariing was 12.2mm wider than the original I had a machine shop turn down my spacer tube by 12.2mm to compensate for this.
Both tubes were done and both were the same when completed, but given my problems yesterday, I'd really like to know what the total length of the spacer tube is supposed to be, just in case my RHS has been squashed a bit and this may have contributed to yesterdays issues.
Even if you could tell me what a new standard sparer tube should be, I can just subtract 12.2mm from that and then check mine.
Luck has smiled upon me.
Imagine finding a 72 model solid rear rotor in Perth, Western Australia that has a fresh grind and is 18.35mm? Freaky, but great!
And I picked up a stock spacer tube also.
Now if Jack or Mike or Larry or anybody can tell me the exact length of a stock spacer I would be most appreciative.
I assembled the drivers side tonight ready for the wheel to go on, and also fitted a set of baby tornado mirrors today. They appear to work really well and look the part.
Jack, I had a good look at the new axles and the sizing is a bit off.
Just below the splines and basically where the inner bearing sits, the axle measure 40.04mm. Then it goes to 40.02mm but right at the outer end of the axle, basically the last 7mm it goes to 40.06mm
That means that my bearing was pressing over 16thou then to 8 thou and then the shoulder of the bearing was pressing on to 24thou as I did the tension up on the nut.
Just too bloody tight.
So it goes to show. I spent the big bucks on what is probably the best product out there with Bob's axles, but even then, they need to be checked and adjusted a little.
I threw it on the lathe and using emery strips I linished off the high spots to give me 40.02mm all the way. So I have a press fit of 0.00078 thou, just under your guidelines.
The replacement rotor will come today so I'll report in on how it all goes together.
Still waiting for a check length on the spacer tube, seems no one has one laying around or that measurement onfile anywhere.
I'm glad you found a stock rotor, Robert. I don't check e-mails daily so I'm a bit late here.
1)-on rotor variations: Dennis Quella in Colorado Springs, CO sells ventillated rotors with an aluminum hat-section that fits over the axle flange front or rear. It obviously spaces the wheel and tire outboard by 3/8" or so. I run '69-76 Porsche 911 ventillated rear rotors with a home-made 1" thick aluminum hat section that fits behind the axle flange as-stock, but is 40% lighter. The vented 911 rear rotor has identical dimensions as stock. Some of the Swedish members did much the same using vented Volvo rotors and home-made spacers. Larry Stock of PPC-Carson City NV sells a Sierra brake conversion for front or rear that uses Porsche 911 rear rotors.
2)- due to the fact that the front bearing is captured between a counterbored step and a steel bolt-on retainer, the inner bearing position floats. So there is quite a tolerance for the inner tube spacer length: the inner bearing can move in or out as required. The only limiting factor is if the spacer gets so short from wear or constant 'squaring-up' with a lathe, that the inner companion-flange adapter for the u-joint bottoms out in the axle splines before you get enough torque on the nut to hold the assembly. Sorry- I've never calculated what that dimension might be.
As long as you're using std bearings, a near- stock spacer length should be just fine. The spacer ends need not be dressed perfectly flat; a few bumps etc won't hurt. On GTS or GR-3 club-racers that ran the optional 10" x 15" Campagnolo wheels and rather wide, sticky tires, DeTomaso used a double-row ball bearing at the inner position for better axle support. The only mod required was to shorten the spacer by the amount extra in the double row bearing. All else stayed the same.
Finally, once you get all this together again, be aware that all 16 bolts holding the halfshafts to the u-joint companion flanges must be tight. If one bolt or nut is even slightly loose, the assembly may yield a 'funny', untraceable vibration under heavy acceleration. If you feel such a thing, recheck those bolts & nuts first.
Thanks Jack.
Interesting info that DeTomaso themselves used the double row inner. I wasn't aware of that. Thought it was a recent USA invention. So that's good for me as I have that double bearing and have which is 12.2mm wider than the stock single race bearing. Hence I machined down the spacers by 12.2mm to 45.7mm total height.
The rotor hasn't arrived yet, Australia is a big country for a truck and apparently we don't have airplanes!
I wasn't happy with the exhaust flange on the RHS headers so today I removed them, welded the flange and have just refitted them. Actually not a bad job, easier than many headers I've had to deal with over the years.
I called Kirk this morning and he will have my small bumpers ready by end of next week so it should fall into place that they arrive as the car gets back on the road.
Removed the clutch master and slave too. Master wasn't fun to get out. Trying to get that pin out above the throttle pedal was a nightmare.
Both are really tired, rusty and badly pitted. They have been sent off to local brake and clutch specialist for a sleeve and rebuild.
Mechanically and structurally, she's going to be good. Hope all this effort is worth it.
Okay, the disc from Perth arrived today and I had everything ready to go.
First stage was to press the outer bearing into the hub and then fit the bearing retainer and the four screws. I used a Loctite stud retainer on these screw and also an impact driver to tighten them securely without damage.
Then a light lubricant to the axle and I offered up the axle mounted to the rotor with the cupped washer in place on the axle. This went into the press and all went together well.
Then over to the bench and I have the rotor face down with the assembly resting on the tips of the studs and I test rotate the hub. Hmmm.....something is binding.
After a while I figure out that the top of the studs are touching on the bearing retainer plate or the four screw. Not good.
So back to the press and remove the axle again, and sure enough there are two studs touching on the bearing retainer ring. Number 11 in this picture.
I'm thinking that these tollerances are just way to close if a coat of thick paint can make the studs rub on this retainer and I start to think that maybe something is missing here?
Back to the parts book and an exploded diagram, and sure enough, I appear to be missing a component.
Now everything that came out has gone back in, no leftovers, so maybe whoever did the last set of bearings or rotors may have left something out.
Part 8 on the drawing below is the specialy cupped washer that goes over the step at the base of the axle. I have this component and it's quite clear where it goes.
Part 9 on the drawing I do not have!
The parts manual calls it up as an outer dust shield, but I have no details about it and certainly don't have them in either side of the car.
Can somone help with this. Please explain what this is, the purpose and I need to know what it looks like as I'm going to need to make this component now before I can put it all together.
And.......bugger it. I'll have to pull the LHS apart agian and fit this in, even though the LHS tensioned down fine and does not touch anything.
  • axle_section
Originally posted by OzGT5:
No Mike, it's only this component called a 'dust seal' and is number 9 in the picture above that is missing.
I called Tony in Perth and his car is exactly the same as mine, and is missing the dust seal part number 9.
The axle spacer is there, no worries.
Well, I messed that up!! My car did not have that part 9 either. In that case there can only be a few things causing the problem:
1. The step on the axel where the cupped washer/spacer fits is not the same as the stock axel. I can’t tell from your picture, but note on my axel images that there is a fairly thick space/step between the rotor mating surface and the area that the cupped washer contacts. The rotor hub should be the same thickness, right.
2. The bearing hub is not the same width at stock. Note that the hub/inner race sticks out some in my images.
3. The wheel stud flange is thinker than stock but I think I recall that you reused your studs.
After following your thread all these months I’m feeling very fortunate that the projects on my car have gone so well.
Mike
Thanks Mike.
The flange that part 8 sits on is 0.35mm higher than the original stock axles. This would have the effect of sitting the cup washer higher, therefore relieving the issue rather than compounding it.
Yes, you may be right and the actual head of the axle where the wheel sits may be thicker by 0.75mm - 1.0mm. This would force the rotor further inboard and may cause the contact.
Obviously last week when I fitted the first hub together, applying the 350 ft/lbs of pressure must have forced the stud heads firmly against the countersunk screws on the bearing retainer and caused the total lockup.
12.11 am in Oz so I'll get up and back to it in a few hours. It's Saturday here so I have most of the day to sort out the issue.
The factory clearance from head of wheel stud to those countersunk head screws and the bearing retainer must be miniscule?
You would like to see 3 or 4mm here to allow some clearances but this seems not to be the case.
I thought the caliper mounting tabs were close to the rotor surface, but the stud head clearance is crazy.
Mike
It's certainly been an interesting few months Mike. It's made more difficult by being on the other side of the World where there are only a (small) handful of these cars and vitually no local knowledge to draw from.
Having Paul locally and Tony in Perth has been great, but without you guys on this forum I would be floundering with little chance of rescue.
You are all great and I appreciate your help.
In another few weeks it should all be worth it, and then I'll start the small jobs like the steering rack mods, electricals, switch gear, console treatment etc.
Will it ever end?
