As I build this thread, I realize how much I owe to my mentor and friend, Wade (4280 / Mark IV).
From the start of my Pantera experience, he has been happy to give me a hand, first with carburetor and distributor advice, and improvement, and then with spectacular fabrication work on both the body and the engine.
Wade has really upgraded this car in one sweeping pass. Some improvements have been required (rust in the upright, ZF Safety Wire), many are to maximize performance (Ported Heads and Manifold, Carburetor work), and others are just for fun (engine build, bay paint).
I feel that in this build, the whole will be far bigger than the sum of the parts.
I am really looking forward to getting the car back on the road, and I owe Wade (4280 / Mark IV) a big "Thank You"! (And maybe a scotch or two!)
PS: Best wishes to all as you head to the Fun Rally - I wish I was going!
Can't wait to see it back on the road!
Joe
Joe
Answer's to JFB and Rodney (UFO-LOW).
The edging material is from Elliot Electronics in Tucson (but we both suspect it can be obtained at any well stocked electronics supply store - maybe even Radio Shack), it is designed for irregular holes to prevent chaffing.
JFB - with regards to the bushings, they are a standard metric size - the id/od/length are mm dimensions 24 x 27 x 29 long.
You may be able to pick them up at a standard bushing house....
Couple of Updates...
Motor goes in tomorrow (that's the plan, anyway).
Here's the fuel system (pump & lines)....
Newly ported Edelbrock Performer Intake Manifold.
There was a lot of material in there that was removed. The porting was done to match the outline of the gasket, which had been previously verified to be highly representative of the port size and shape.
Don't want my heads to be restricted by the manifold that feeds it!
OK - Back to work!
OK - Back to work!
hope you had a productive day!
Engine Install Day! One giant leap forward for my project!
What a feeling of progress!
Wade came by and we knocked out a big chunk of the "endgame" work. We got the motor checked out, and installed. Lots of little items that had been on hold were accomplished. Here's some highlights....
Motor Mounts and Formed Heater Hoses...
There is a shielded sleeve for my heater control valve. This valve will be operating in the engine bay, vs. in the cockpit. The formed hoses are the shizzle for the Pantera application.
The brown wire will mount to the oil temp sender in the front of my Avaid 10 Qt oil pan. The plan is to wire it through the "spare" switch on the dash, so I can check oil or water temp with the flip of a switch.
Oil Pressure Verification - SUCCESS!
A broken distributor and a drill makes a cool oil pump driver. A spare oil pressure gauge tells the tale. At idle speed (actually, well below it) the motor was registering 25-30 psi. At slightly higher rpm, the oil pressure relief was opening at 75-80 psi. Just as we had planned.
An Old Racer's Trick - Right Steve?
These petcocks on both sides of the block let you drain down the coolant when needed. This allows you to make much less of a huge mess.
I would venture to say that these petcocks add about 5-6% more cowbell to my engine build (each!).
In She Goes...
Not much more to say here...
In The Bay!
Still have to do electrical checks, ZF Fill, coolant fill, and some work is still needed on the exhaust, Bulkhead Cover (alternator clearance) and lots of other little stuff. But the day will soon arrive for the break-in and then... the sky is the limit.
In She Goes...
In The Bay!
Cool Trick - When You Drop a Nut inside a Non-Ferrous surface... (Like in the Motor Mount)
A magnet ball inside a baggie can get in where your fingers can not.
I am sure this would work in a magnetic area as well, you just have to figure out a way to get the magnet into the area where the missing hardware is located.
I didn't understand about the heater control valve. did you take a photo of its installed position?
It's not in quite yet...
I'll try and post up a picture of the valve style....
Rocky,
Nice job on the petcocks! Now I I could just remember where I saw that before.
Remote heater valve is the way to go. I did an electronic one but still good idea to get it out of the cabin. I'm looking forward to hearing you got it out on a shakedown cruise.
Steve.
Steve.
Steve.
Steve, How did you control the coolant flow through the valve or is it simply full open or fully closed?
Doug M
* * UPDATE * * Cable Controlled Heater Valve
I found the cable controlled heater valve that recirculates to the pump when the valve is in the closed position. This valve cost about $18 at the local parts store.
This valve will be going in the engine bay, and will eliminate flow into the cockpit when shut off. I am using a cable system from the original heater lever. We will have to fab up a little bracket / cable clamp to mount the cable, and to position the bracket in the engine bay area.
[url]=http://s1298.photobucket.com/user/Rocky_LC/media/351C%20Engine%20Build%202013/06-26-2014108Medium_zps82ad7750.jpg.html]
[/url]
[url]=http://s1298.photobucket.com/user/Rocky_LC/media/351C%20Engine%20Build%202013/06-26-2014111Medium_zps1734910d.jpg.html]
[/url]
[url]=http://s1298.photobucket.com/user/Rocky_LC/media/351C%20Engine%20Build%202013/06-26-2014110Medium_zps583cfaf4.jpg.html]
[/url]
I am removing the original valve in the front - it is VERY stiff, and just replacing it with a 90 Deg. brass elbow.
* * * Another Update - Electronic Heater Valve! * *
This is an electronic version of the one that Wade and I are working on.
Electronic Remote Heater Valve
Dave (2811) has one of these babies, as you can see in his picture (Post #2 of this thread)
Dave 2811 Remote Heater Valve
The old valve I posted will be going back onto eBay when I get some time. It's not really what I was looking for.
Doug M
Doug, I will send you a PM. Don't want to steal Rocky's post.
Headers -
So my car came with a set of "Big Bore" headers (at least that's what I think they are). Looking at them, they were coated, and in good shape, but when looking in the collectors, we noted significant restrictions to flow. Since we were optimizing flow in this engine build with porting of the intake manifold, intake ports in the heads, and the heads themselves, it didn't make any sense to have restriction in the exhaust.
![photo 06-17-20141Medium_zps3b9d943d.jpg~original[/IMG] </a><BR><BR><a href=](http://i1298.photobucket.com/albums/ag42/Rocky_LC/351C%20Engine%20Build%202013/06-17-20141Medium_zps3b9d943d.jpg)
![photo 06-16-20145Medium_zps83eaaf0f.jpg~original[/IMG] </a><BR> <BR><a href=](http://i1298.photobucket.com/albums/ag42/Rocky_LC/351C%20Engine%20Build%202013/06-16-20145Medium_zps83eaaf0f.jpg)
![photo 06-17-20144Medium_zpsfe354a8b.jpg~original[/IMG] </a><BR><BR>The header attachment bolts were machined with a locating boss in the bolt flange. This allows a more positive header alignment, and helps to prevent the bolts from loosening up. It's a little tougher to see in these pictures.<BR><BR><a href=](http://i1298.photobucket.com/albums/ag42/Rocky_LC/351C%20Engine%20Build%202013/06-17-20144Medium_zpsfe354a8b.jpg)
![photo IMG_1229Medium_zpsb3289aa1.jpg~original[/IMG] </a><BR><BR><BR><a href=](http://i1298.photobucket.com/albums/ag42/Rocky_LC/351C%20Engine%20Build%202013/IMG_1229Medium_zpsb3289aa1.jpg)
![photo 06-17-20148Medium_zpsa943d280.jpg~original[/IMG] </a><BR><BR>Tubing to the mufflers will be upgraded to 2-1/2](http://i1298.photobucket.com/albums/ag42/Rocky_LC/351C%20Engine%20Build%202013/06-17-20148Medium_zpsa943d280.jpg)
PS. This is another example of master craftsmanship by Mark IV / 4280 - thanks, Wade for the help.
Here is why I have been out of touch - 3 weeks in the mysterious Orient (Turkey) with the family.
Are there any Pantera owners over there?
Istanbul
Herikaya
Cappadocia:
Fetiye:
You would not have believed the roads. We drove 3850 km (about 2400 Miles in 3 weeks).
In all that time, I only saw one cop actually enforcing speed limits. Since we lived there 16 years before, the country has developed an amazing network of roads. I wished I had my car with me. I am not kidding, it really would have been a BLAST to do 2500 miles in a Pantera over there!
Istanbul
Herikaya
Cappadocia:
Fetiye:
just from the few photos, those three weeks must have been great!
JF - We had a blast. It was an unbelievable adventure.
Compressor Bracketry - Fitment & Install
So I have finally got my compressor / alternator bracketry installed. It took a couple of "ins and outs", primarily because of the additional thickness of the extra insulation and the Stainless Steel covers on the rear firewall.
It is the same basic design as the "David Nunn" setup - his is on a Fontana Block, mine is the stock 351 Ford. Here's a link to David's Awesome motor...
Fontana block a/c compressor bracket
My setup is in the car now, and I expect it will stay in there. Things are very tight - I need to be careful of my grounding wires, my heater hoses rubbing on the idler pulley, and the alternator fan rubbing on the SS panel, but it looks like we have solved the major fitment issues, thanks to my buddy Wade (Mark IV / 4280).
Oil Temp Sender
The oil temp sender is in the front of the Avaid 10 Qt pan. It is the standard water temp sender that Neil (my PO) won at a POCA Fun Rally raffle about 6 years ago. It will be wired through the spare switch so I can check oil or water temp on the same gauge.
Bracketry Install
Here's some pictures.
Oil Temp Sender
Bracketry Install
question about your belt drive axuilarries. I can't recall how the original fit and the reason for the offset bump in the bulkhead cover.
so, to be able to reduce the bump to just over engine center line, the belt drives are places low. Is it the slope in the fire wall that allows the pulley/belt not to protrude into the passenger compartment?
JF -
Check out the pictures on page 3 of this thread. You can see the little lip that clearances the belt.
But you are right, the slope of the firewall also provides some clearance.
Sign In To Reply
