Ron, do you have any of the following:
1. Rear bumpers
2. Ghia badges
3. Engine cover - square metal bubble for the interior
Thanks, Steve
Steve,
I have #2 and #3 but the only rear bumpers that I have are fiberglass versions of the Euro rear bumpers.
Ron
Ron
Ron, I sent you a PM.
Ron,
Also sent you a PM. Do you have any sugar scoops and any additional bumperettes (front and rear)?
Ron, sorry for using your site. I wasnt sure if it was for everyone or just yours. Never meant to butt into your business. have a Happy New Years, mike mayberry....
No worries Mike.
Ron
Here is a list of the parts that I have for sale :As of 1-4-11
1 pr. Pantera doors ( primer ,completely rust free)
14" chrome air cleaner (Summit Racing)
Original air cleaner lid ( Decent shape)
2 Front grills (1 early,1 late)
2 Steering columns ( 1 complete one missing lower shaft,plastic cover etc.)
1 Speedo cable(used ,good shape)
3 rear tag brackets ( 2 w/ broken studs)
2 tag light assy (1 missing lense cover)
1 brake pedal stop
2 red clutch slave lines
1 late seat belt ( rough)
25 sway bar brackets
12 sway bar bushings
1 set of sun visor clips
2 wiper transmissions
Bag of brake caliper spacers
Used suspension bolts
2 pr. sunvisors ( 1 rough, 1 fairly nice)
2 Hall Pantera center consoles ( pretty rough)
1 pr late kick panels ( good shape)
1 York AC compressor
2 emission valves w/ hoses
4 charcoal canisters (2 large,2 small )
1 set aluminum motor mounts
9 motor mount bolts
2 1/4" mount spacers
1 bottom (frame section) motor mount
1 water pump pulley
5 radiator air deflector shields(2 rt,3 lft)
5 front fender splash shields
1 pr 64-66 Mustang defroster ducts ( new in bag)
1 Holley mechanical fuel pump (chrome)
1 windshield wiper motor
3 pr stock tail lights ( one with broken lense)
1 rt tail light
1 pr Dortmund door speakers ( match stock door covering)
1 tail light gasket
1 shift gate ( rough)
1 shift handle ( needs rechromed)
2 tail light lenses (decent shape)
1 pr 1/4 window assy (polished trim and rubber)
1 pr 1/4 window rubber
1 left side 1/4 window ( black trim /rubber)
1 vent window rubber
1 pr 1/4 window trim (polished)
1 rt 1/4 window trim ( primer)
2 pr wiper grills ( wiper hole on rt)(excellent shape)
1 left metal "gill" (14 rib)
4 Rubber boots for shocks
Late (single pod) AC /Heater box (Complete)
Paper hoses for ducts
5 upper rear control arms ( w/ balljoints)
4 urethane control arm bushings /sleeves(new)
2 pr lower front control arms
6 lower rear control arm mounting brackets
5 early fuel filler flanges(3 w/ caps)
2 sets steel radiator tubes ( front by radiator)
1 metal thermostat pipe ( slightly bent)
1 NOS steel tube ( to pressure tank)
1 NOS steel tube (short elbow)
1 steel lower water pump tube elbow
2 steering rack braces
2 battery hold down brackets
1 early relay cover ( with holes in it )
2 stock spreader bars
1 aluminum banjo fitting ( brake booster)
2 gas tank mounting straps
2 windshield wiper arms ( silver)
1 fuel tank vent
1 pr door latches
1 left door latch (rough)
2 door handle mechanism ( 1 nice(no spring) 1 rough(w/spring))
1 horn bracket
3 windshield washer bottle brackets.
2 park brake lever ( under car)
1 firewall bracket ( for coil,voltage reg starter relay etc)
1 pr DeTomaso aluminum valve covers
1 Park brake handle (inside car)
1 pr horns
1 set (4) new chrome exhaust tips
1 rear view mirror & mount
1 NOS exhaust hanger (rubber)
1 windshield washer bottle.
1 brake booster.
1 shifter assy
1 shift rod (w/ adjusters)
2 sets power window regulator assy
2 rt side door glass tracks
1 window motor
3 headlight motor assy ( 1 missing motor)
AC condensor shroud /fan assy
8 steel coil spring retainers
4 rubber spring isolators
6 aluminum spring spacers (4 short,2 tall)
Alt/AC bracket w/ alt and upper bracket
5 "half moon" steel coil spring locks
4 coil springs ( stock)
1 rear L-model bumper shock
1 Edelbrock F351-4V aluminum intake manifold
1 inside door release handle ( left )
1 cast iron brake valve. Sale pending
8 rear deck lid hinges
1 front hood hinge
1 Motorcraft ballast resistor
1 pr weld on brackets for rear splash shields
1 engine bay emissions tag (great shape)
2 rear brake caliper brackets ( bare metal)
1 radiator pressure tank ( bare metal)2 pr radiator fan mount brackets
1 left early (square) front bumperette(primer)
1 left later ( round) front bumperette( black)
1 complete pedal assy( with clutch effort reduction)
3 AC condensor grills ( 1 bent, 2 nice but all missing 1 stud)
1 ignition switch
1 pr cheap GP4 tail light lenses ( black trim)
1 tachometer(w/ harness and plug)
1 Hazzard switch
1 Oil pressure gauge (70 psi)
1 fuel gauge
2 dash light dimmer switches w/ knobs
1 grill crest bezel( rough shape)
1 hood release handle ( rough)
1 dome light switch( nice)
1 decklid striker plate
1 wiper switch (late,bad chrome)
1 pr brake/clutch pedal return springs
1 hood latch/release handle /cable ( very nice)
1 hood latch
Pantera emblem ( rough ,missing stud)
DeTomaso emblem( good shape)
3 Door strikers w/shims
1 pr chrome side mirrors (decent chrome)
1 small plastic trim ring for ignition switch
5 plastic side marker light bezels
2 Aluminum side marker light bezels. Sale pending
2 amber side marker light lenses.
2 red side marker light lenses
1 pr Front turn signal light assys with gaskets (no lenses)
1 pr Front turn signal light assys with gaskets ( decent shape with plugs and lenses)
1 NOS Front turn signal light assy ( No lense or gasket)
1 pr Front turn signal light gaskets (used)
1 pr side marker light lens gaskets (used)
1 door handle key hole ( rough)
1 chrome AC temp control bezel
1 used rear deck bumper
1 set (8) NOS Champion spark plugs (RV 12YC)
1 set Sears Contact points and condenser
1 Rear upright assy (complete)
1 Rear upright assy (bare)
1 early rear transmission mount
1 stock axle w/ flange
4 axle flanges
6 stock halfshafts
2 pr front brake calipers
AC condensor fan/motor (broken blades)
1 Left front brake rotor /spindle assy
1 left front spindle assy ( bent steering arm)
3 steering arms ( 1 left,2 rt)
3 spindles ( 2 left ,1 rt)
1 Alternator (used)
1 NOS nut ( Part # 0051116)
2 sets wheel bearing,nuts,dust caps (used)
1 set NOS dust washers ( Part # D3GY-1180-B)
Various dush shields, spacers,washers (suspension)
1 NOS axle bearing retainer ( part # D3GY-4020-A)
1 pr (2) Koni shocks ( need rebuilt)
2 front brake rotor /hub assy
2 rear brake calipers w/ brackets
Assorted rear brake parts
5 front brake rotor dust shields
2 stock brake fluid reservoirs
1 brake switch fitting
1 Hall Pantera Ignition box (with pigtail connector)
1 pr headlight buckets( primer) chassis # 4006
1 pr headlight buckets ( bare ) chassis # 6714
1 pr headlight buckets/light assy ( yellow)one smashed up a bit) chassis # 6740
1 pr headlight assy (nice)
Misc headlight retainers/brackets/trim rings/gaskets
3 headlight trim rings( 1 nice ,2 rough)
1 steel engine "hump". Sale pending
1 stock radiator
2 gas tank heat shields
3 A-pillar interior trim (black)
2 front interior trim covers(white)
2 side interior trim covers (white)
2 rear interior trim covers ( white)
R&L polished stainless "rain gutters"
1 LOng steel vacuum tube (under car)
Many assorted stainless steel trim pieces for doors/windows (most polished)
3 carpeted fuse panel/relay covers (very nce) (1 rt ,2 left)
1 brake pedal stop
9 motor mount bolts
1 water pump pulley
1 rt tail light
1 tail light gasket
1 fuel tank vent
1 pr door latches
1 horn bracket
1 pr horns
1 brake booster.
1 shifter assy
1 window motor
1 front hood hinge
1 ignition switch
1 Hazzard switch
1 fuel gauge
1 hood latch
4 axle flanges
6 stock halfshafts
1 Alternator (used)
1 stock radiator
The 1/4 window rubber. Is this for the windows in front of the gills? If so, is this new or used?
PM sent.
Thanks,
Mark
Thanks,
Mark
Steeve,
I will PM you my grocery list.
Serge
Serge
I think I have replied to everyone.
Thanks,
Ron
Thanks,
Ron
hi ron,private message sent regard tony
PM sent!
Thanks,
Ron
List updated!
Ron
Ron
OzGT5 (Guest)
No door glass? I would like to replace my side glass as they are badly scratched.
By updated do you mean sold items have been deleted or new items added?
Sold items and sale pending items have been marked.
I will erase the sold items next.
Ron
Ron,
Did you see my PM? I'll take one of each of the rear lower control arms and the 2 pipes mentioned.
Dan Jones
Dan Jones
quote:Originally posted by Daniel_Jones:
Ron,
Dan Jones
PM sent.
Sorry Dan.
ROn
Sign In To Reply
