Over twenty years ago we removed a passenger door from a'72 Model. If I haven't done anything with it in 20 years, I guess it's time to find someone that needs a door. It's gutted, all parts removed and used in the replacement door. It was hit in the center. Needs either body work or preferably a $300.00 skin. Door frame is ~not~ bent. Upper glass frame is original and unhurt. Door sills ft. & rear fine shape. It was hit almost dead center, although the hit is shallow, it did ~not~ break the glass or affect the regulator, both of which we reused. $1,500.00 or best. Sharkey
