Damn nice looking, and I bet it moves too! What is the estimated HP? Ford or not, as long as it looks good, sounds good and snapps the neck, it's good to go in my book!
Wow that is a bitchin' motor!... how about a shot of the adapter plate for the trans axle... and do you have the front pully system worked out yet (Pantera)??... Please keep us posted if this is for a cat build... That thing is a super ZL-1, nice!...
It is a big block chevrolet Greater then 400 No adapter plate. Welded and drilled orginal bell housing. Have had it in the car, but redoing the pullys because thinking of using electric waterpumps and different alternator.
