Looks like he bought TWO of them...  !!!  The orange one is 8MA*882 purchased 17, April 1969 and the blue one is 8MA*886 purchased 9, May 1969.
The differences I've spotted are:
886 has odd double turn signals on front that 882 does not have
886 has VERY old window sticker behind driver that 882 does not have (882's pictures are older)
886 has a light next to the ignition key that 882 does not have
886 has different (odd) AC vents, 882 has typical vents
AC condensers are different
886 has no armrests, 882 they are typical
886 has the combined window switches, 882 has the separate switches
886 has a different double labeled MPH&KPH speedo that 882 does not have
and of course the paperwork differs...
Wow...
MH
Images (9)
  • mceclip0
  • mceclip1
  • mceclip2
  • mceclip3
  • mceclip4
  • mceclip5
  • mceclip6
  • mceclip7
  • mceclip8
so darn interesting...my guess, a lot of things were 'lost' during the hot rodding and restoration (for example, the Speedo is probably from a Longchamp...the clock and ammeter from wherever...and those wheels, the uncanny valley...).  But most interesting to me is that these were genuinely attributed as 289 Hi-Po (305 HP...). The '305 hp' quote is oft repeated...
(wow, and adjacent motor numbers, at that...)
Far right hand lower corner...around the heat wrapping--there it is, the heat riser for the choke !  Years ago when I swore that the carb was 'rotated' (180' from the way Ford installed it...) and the convincing proof was that the heat riser for the choke was on the left header---but Denis insisted that in fact, he'd seen the riser on the right header....
...and of course, I still didn't believe him...but a few weeks ago he sent me a pic. And now in this car, maybe a clue that these were in fact used for the fabled 289 Hi-po...
   And lesson learned--never doubt Denis
  • mceclip0
