Well, the Zf is coming out. The disk is toast. I've always taken the ZF out with the motor or my last car had the rear mounts modified so I could slide it backwards for easy removal.
How do I remove the ZF by itself? I remember reading that I've got to jack the motor up slightly? Do I need to reove the motor mount bolts? Obviously, the coolant lines need to be disconnected?
I only have a few days before Niagara Falls so I need to make this happen.
Thanks in advance, Will
