This is from the Pantera Service Highlights.
Rear Suspension
Upper Ball joint to Upright 58 ftlb
Lower upright rod to A Frame 95 ft lb
Upper A Frame to Chassis 58 ft lb
Lower A Frame to Fork Bolt 50 Ft lb
Lower Fork Bolt to Chassis 43 - 47 ft lb
Shock absorber mounts (upper and Lower) 50 ft lb.
Axle shaft flange bolts 50 ft lb
