Can someone confirm what the correct SKF rear wheel bearings are? . Want to buy a quality bearing like SKF and use a wider inner bearing.
I found these, but want to see what others have used. I see there are metal or polymer cased ones. When I removed the old ones, one axle side was metal and the other side had polymer. Is one better than the other? I hope to buy quality parts and only have do this once.
SKF 5208 A-2RS1 . This is the wide inner bearing, and is an angular contact bearing.
SKF 6308-2RS1 - The outer bearing.
Thanks,
John
