It looks to me like I'm not getting full tire contact patch with the road. It seems that the outside edges of the rear tires are always black, when they should have dirt on them like the rest of the tire.
They look straight when viewed from behind, and down the side of the car. They look like they're at the same angle as my front tires too. The documentation I have with the car claims that the rear control arms were replaced with extended ones to minimize rear tire wear. This was done about 10 years ago.
Has a different or better fix come out since then that can help me correct this before my new rear tires start to wear unevenly?
Here's a picture of the tire tread with the dirt pattern.
Michael
  • Rear_Tire_Dirt
They look plumb to me, but the tire wear will tell all. Probobly what happens is under hard acceleration, she squats a little, and wears inside, you should drive hard on some winding roads to even out the wear. Just kidding! I'm still giggiling from the detective work on the fuel pump!
Michael -
It doesn't help you any, but my rear tires do the same.
I brought it to an alignment shop to correct it, and they told me that they had already dialed out all the camber they could. The way to solve this problems is with the aftermarket a-arms, which you apparently already have?
As a short term solution, I rotated my tires so that they would wear the "other half" a little more.
I guess what I'm saying is that the late model wide-body cars may come like that from the factory? Can you dial it out with your aftermarket a-arms?
One other thing that comes to mind - PLEASE PLEASE look at the attachment point of the a-arms to the chassis. My upper a-arm literally pulled through the chassis (photos available upon request) and it would have been really ugly had that not happened while my car was being dragged onto a flatbed. (my guardian angel really does a decent job sometimes). If you cannot get the camber you want despite aftermarket a-arms, perhaps it is because your upper a-arms are starting to pull through the chassis?
DeTom,
I really don't think they're rubbing anywhere. I paid special attention to that after installing the wheels. I even took the wheels off after some mileage to make certain the tires weren't contacting anything (and they weren't). I will take another look, though, just because anything is possible.
The first picture of the tire was taken in my driveway after driving about 20-25 mph through my neighborhood on the way home. The tire should've been rolling flat.
Could it be the car and tires are so wide that the edges of the tires are actually hanging off the crown of the road? It seems like a stretch, but I'm examining all possibilities at this point.
Michael
Charlie,
I saw some pictures years ago of a white 5-S with the right rear inner tire so prematurely worn, that the belts were hanging out! The tread on the other side of the tire looked good. It was on a flatbed.
There were also pictures of the lower control arm on that side that had pulled the bolts through the frame rail. It did not look pretty. Was that your car?
In any event, thank God that didn't happen to you on the road!
At some time in it's life, my 5-S had a modification performed on it that addressed this problem before it happened. Plates were welded along the inside of the frame rails where the control arms bolt through to strengthen these areas. I will inspect those areas just to make sure they aren't failing.
Thanks for the suggestion, Charlie.
Michael
Well the reason I said that is the pattern is the same on mine, only mine are a lot worse. It only happens when the upper limits of suspension travel are reached. I have since, just this past weekend, corrected mine. All I had to do was re-install the crossmember bar correctly and they stopped rubbing. I even posted about it because I was tickeled pink by it. Wink
DeTom,
Yes, I remember the post. Something so simple correcting something major is always great to read about!
Any and all suggestions are appreciated, thank you. I'm going to take the wheels off and examine the wheel wells for rubbing, the control arms to see if they actually are extended, and the frame for pulling. I don't expect to see anything wrong.
I don't remember seeing this with my 15"s. I wonder if the increased diameter of my new rear tires amplifies the original deficiency? We may be in new territiory here!
Charlie,
Did you notice a change in handling or control prior to the control arm looking for a solo vacation? Or did it just happen all at once? If you can find the time, I'd like to hear the story of your control arm woe.
Michael
Michael & all,
Recipe for George's handy home camber gage:
You need a length of 1/4", 3/8" or 1/2" steel square stock, cut to length so that it fits from bead to bead on your wheels without hitting the sidewall of the tires or the extreme rolled edge of the wheels (a little over 19" in Michael's case). Now acquire a large calibrated angle/protractor bubble level with a magnetic base. The good ones are calibrated to +/- 0.5 degrees. The larger the scale, the easier to read differences in angle.
Hold the steel stock vertically from bead to bead across your wheel & attach the level, you can get a fairly accurate reading of camber. Much more accurate than your eye, and more convenient than driving to the alignment shop every time you want to monitor your camber setting.
There are also decent home / track side alignment tools sold by several companines in the $600 to $1K range.
This problem is why there are adjustable camber bars & adjustable upper rear control arms sold for the Pantera. The additional force applied to the chassis by wider tires accelerates the problem, and the wider spacing of the rear tires on the GT4 / GT5 / GT5-S increases the force even more. It doesn't take much "flex" or "give" in the chassis to throw the camber off & the wider the tire OR stiffer the sidewall, the more sensitive the setting is.
I am a new Pantera owner, but I'd bet a round of drinks that the chassis flexing at the upper rear control arm could be reduced if the mounting of the camber bar were spread out, attached at 3 points on both sides rather than just one.
your "1/2 a bubble off plumb" friend on the PIBB, George
Mike,
From my experience it appears the uppers are too short in theory. when the car squats under acceleration the lower becomes level or longer. This creates a situation where the inner tire as of now has more contact and under acceleration as the lower increases in lenght the inner contact increases and out tire contact decreases. You have to create a compensation for the problem. Remember this is my first Pantera, but have played with the geometry of supsension a lot. I'm not familiar with your exact supsension, but it appears my car has shims on the lowers. I have not looked closely at the uppers. It would seem correct that they need to be shimmed out in your case ? This is just my 2 cents.
You guys are on the right track. Few realize that the removable cross member bar in the engine bay helps locate the upper a-arms. To get your rear suspension geomotry right you have to install it with no load on the rear wheels. Do not pre-load the member, but have all the weight off the wheels and then install it. And really crank down hard on the bolts because it will be under load once you lower the car back down. When I did this I gained almost a quarter inch of extra space inside the sidewalls of the engine bay. It is a miracle I tell you!! Imagine just doing something so small making such a huge differance in how the car feels. All you have to do is read this board and the email letter and you pick up on all sorts of cool stuff.
I'm not having any handling, suspension, alignment, or body flexing issues. The car handles very well, and is steady and predictable. The tires aren't even wearing unevenly, and I've got a few thousand miles on them already. I just don't want to ruin a brand new set of tires if there is a camber issue.
The ideas and suggestions are great, though, so keep 'em coming!
Michael
Originally posted by Cyboman:
Charlie,
Michael
Yes, both of those were my car. It's a very long story, but I have a rather extensive collection of photos of my car on a flatbed tht I accumulated during the first year or two of my ownership. Knocking on wood, I think that is all behind me now...
Charlie,
Michael
No, I noticed no change in handling. Although to be honest, I was possibly so concerned about my engine falling apart that I wasn't concentrating on the suspension. I was on my way home from an International DeTomaso meeting in Italy, so I had been "highway droning" on a long and straight highway for several hours.
Ironically, I was probably saved by the fact that my engine did eventually eat itself, so I pulled over and called a flatbed. At some point between loading and unloading the car, the rear wheel fell off. Well, the upper a-arm pulled through the chassis. I'd spent much of the prior week driving through the Italian Alps at highly anti-social speeds, including an organized hillclimb event. Had that wheel come off a day or two earlier.... But I suspect that the stress of doing so was the straw that broke the camels back on my suspension.
I agree with George Pence. Have it measured. Camber angles can be deceiving. I have been working at a brake and alignment shop for the past fifteen years. I trust my eyes, but I trust my levels more. On another note, don't be afraid to run tire pressures close to the max. pressure setting stamped on the tire sidewall. In todays world of low profile tires, its a good practice to keep that sidewall firm and the tread planted on the ground. 1/4 negetive camber, 0 to 1/8 toe in at the rear would be a ideal setting. Thats were I will set mine this weekend.
I drove my Pantera around quite a bit this weekend. Everytime I got out I looked at the rear tires, they had even dirt across them (so did the fronts). Maybe it's just my driveway. I'm still going to check everything over, but I've added it to my 'winter' list as it's not a pressing issue. I'll post what I find.
Michael
Actually DeTom, the right way to adjust the cross member bar is to jack the car up from the center rear so the rear wheels are completely off the ground and hanging. Then expand and tighten the center nuts on the cross member bar until it is snug against both holding brackets on each side. Both sides should be very close to the inside upper wheel wells just beyond the holding brackets.
However, you have to make sure that the cross member bar is actually equal on each side of the mounting area's. I oblonged the holes on each mount that holds the cross member bar so that it would expand where it should be on each side equally givng the rear the equal support it should have on both sides.
Hope that makes sense.....
I learned this lesson from Les Grey and now my rear tires are wearing even across.....
Coz -
If you do as you suggest, aren't you erring too far the *other* way? You shouldn't install the cross member with the chassis loaded, I agree, but I thought I heard you shouldn't install it with it completely UNloaded either. Going by memory, but I thought you should put a jack under the car and lift, but not enough enough to remove all the weight from the wheels. You want them 50% or loaded or so, so that you don't lock everything in an un-natural position - either completely loaded or completely unloaded.
Of course all this is "locker room type" hearsay, and have no idea how much is true...
(on the other hand, perhaps that is why my tires still wear more on the inside and the alignment shop says they can't adjust them any further???)
Charlie,
If your tires are still wearing on the insides, why don't you try totally unloading the rear suspension and reinstalling the camber bar? It may help somewhat.
Michael
Thanks Michael, I may do that next time I change tires. Right now I *need* them to wear on the inside because I rotated my tires and put the more worn part on the outside. I need them to wear so that they are more or less even, then I may try reinstalling the camber bar.
Thanks for the suggestion - I need to do *something* - those tires are getting hard to find!
Charlie,
Not really. When you raise the car totally off the ground, you take most of the loading off the cross member. Adjusting it at that point so it's snug and putting equal pressure on both sides, as long as both sides are even with the placement of the cross member in relation to the inter fender wells. When you lower it back onto the tires is when you are actually fully loading the cross member.
For it to perform as it should, it has to be fully loaded when on the ground.
You would never be able to completely pre-load it with the wheels still on the ground unless you were King Kong. Let alone get the member out or in for that matter.
That's how I was taught to do it....and my tires are wearing evenly.
If your tires are wearing on the inside, my first guess is that your not loading enough and they are collapsing inward.
