I just found a company in New York that can rebuild the clutch master cylinder. It is called Apple Hydraulics and their phone number is 631-369-9515. It is a bit expensive, but they will bore and sleeve the cylinder to 3/4 inch. My clutch master cylinder just failed and the OEM replacement that I bought from one of the Pantera vendors wouldn't fit in my car. The master cylinder bellows boot was too thick to go through the pedal box. I have two worn out clutch master cylinders and I might send them both units.
Simon, do you know Mark Johnson at IPSCO? The long throw slave might be one of those items he makes for Vendors but doesn’t sell direct. Might be worth sending him an e-mail.
