I have a 72 Pantera that has speakers in the door panels that I want to remove which will require the door panels to be recovered. is there a material available that closely matches the original? some of the older posts mentions a member named Gary that does interiors. is he still doing that work and if so does anyone have his contact info? thank you for the input.
