Originally posted by 1Rocketship:
Have you pulled both valve covers to see if there as any more "Mix & Match" rockers?!
I'm "CONFUSED" ( rarely happens
If Jesel rockers are rebuildable & Jesel warrants their products...WHY did Rodger ( previous owner) not have the failed Jesel rockers rebuilt/replaced instead of substituting T&D rockers for the failed Jesel rockers?!
I have up to this point chosen NOT to comment on the Previous owner's ( Rodger's) forthright fullness in disclosing the condition of the Pantera, that being stated...I would be PISSED to pull a valve cover/s only to have revealed two DIFFERENT types of rockers!!!...Mark
Irregardless of which rocker arm is in there, neither is cheap and neither is junk, you presume that the previous owner used NEW rockers and the fact is he might have bought the heads and rockers as a set used that came out of someone else's race engine. Maybe the camshaft setup as well.
The significant part of that is there would be NO WARANTY on any of those parts that I know of? Fits into the scenario if you ask me?
Actually the mixing of components here indicates some higher specialized knowledge, not someone guessing at things?
Take all the cheap shots at the seller you want. It takes an upper level of specific knowledge here to even realize what is going on.
This WAS NOT done by a simpleton NOVICE. Someone here just made some decisions that indicated they wanted a VERY specialized RACE engine to use limitedly on the street.
The misrepresentation was CAUSED BY a novice BUYER that believed he could use this engine like a normal street engine without almost daily maintenances AND CHOSE to hear only those positives? The seller was accentuation the positives.
This is not the first time this has even been brought to light on this FORUM. "You" can explain until you are blue in the face but the buyer simply does not know WTF you are talking about, then when they buy the product or the bill of goods, then all they do is bitch about how they got taken. Get over it. You the buyer caused this. NOT the seller.
Frankly I think you have found a very polite audience here to even listen to this crap?
The term "Jessel" has become to mean a "generic" shaft mounted roller bearing rocker arms and I suspect that was what was done here? If he said T&D, would you know WTF he was talking about? I'd bet no?
Racers selling off their previous set ups happens a lot since they often update last years components to this years hottest setup. I'd guess that's where the entire top end of the engine came from?
To put everything new in that engine is quite a few thousand dollar bills. It's possible but personally I highly doubt that.
IF you insist on a roller lifter camshaft you are MUCH MUCH better off with the hydraulic version but even then you are complicating the valve train to a power of an unknown factor.
What's wrong with going to a flat lifter camshaft? Do you just NEED this DAILY DRAMA in your life? WE DON'T!
Maybe you can start a cable reality show?
Being NO stranger to controversy, I'll do a triple gainer off the high dive into the pool of second opinion.
Firstly...This statement of Dougs's is counter-intuitive to engine building in regards to specifically the valve train
"Actually the mixing of components here indicates some higher specialized knowledge, not someone guessing at things?"
A expertly assembled valve train is NOT a hodgepodge of mix & match roller rockers.
The fact is was a "Mix & Match" indicates to myself that something is WRONG with the valve train that has caused various rocker arms to fail over an extended period of time.
Secondly...Doug's statement...
"The term "Jessel" has become to mean a "generic" shaft mounted roller bearing rocker arms"
Could not be further from the truth. Jesel is very much a Brand specific, highly regarded, EXPENSIVE roller rocker & is NOT to be confused nor mentioned in the same breathe as a cheap Chinese knock-off brand. Ferrari & Yugos are both "cars", but never cross-referenced!
Doug cannot claim in one breathe that "Rodger" knew what he was doing when building a "Race Engine" then claim that Rodger used a "generic term" when Rodger mentioned the engine having Jesel roller rockers, ESPECIALLY considering Rodger's intimate experiences with rocker arm failure in this engine.
Thirdly...Doug's "Guess" of the building for the engine...
"Racers selling off their previous set ups happens a lot since they often update last years components to this years hottest setup. I'd guess that's where the entire top end of the engine came from?
To put everything new in that engine is quite a few thousand dollar bills. It's possible but personally I highly doubt that".
I've built countless engines & personally have NEVER installed USED racing components, as I'd rather have ALL NEW & spend a few thousand more...then have my USED race engine components built engine BLOW UP & have a lump of expensive mangled iron...
The old adage..." A penny saved a pound foolish" applies.
Doug is CORRECT & I AGREE that buying a car, ANY car with a "Highly Tuned" engine is fraught will a myriad of potential problems & is truly a caveat emptor situation.
Lastly...Doug's statement of Mike's possible career in T.V....
"Maybe you can start a cable reality show?"
Unless Mike has a sex tape, a bulbous Ass like Kim Kardashian & a father undergoing gender reassignment surgery, I'd say with a profound degree of both certainty & confidence! that the
"Mike the Snake Pantera Saga Story" reality show will Never leave the can...Mark
