Is there any down side to reversing the output shaft so that the thicker end is closer to the upright?
quote:Originally posted by jimmym:
Thanks guys for the replies. I had thought about the unsprung weight as a potential issue but wasn't sure if it would make that much difference.
quote:Originally posted by Joules:
... CV axles are much thinner than the half shafts, if clearance is a concern you could always ...
quote:Originally posted by Rocky:
I agree with Doug & Jack...
The only real reason to do this is for exhaust clearance. I went to larger diameter pipes, and the swap-around was required, as well as a large number of suspension swings (shocks and tires removed) to verify clearance.
Like Steve, I have the 2 1/2" pipes. My buddy modified the collectors on my headers, and then ran larger diameter pipes to the stock ANSAs.
ANSA -1 Build
Anyway - if you are going even bigger, it's going to be tight. You may have to follow Julian's advice on the 180s!
Good Luck.
quote:Originally posted by PanteraDoug:
Talking about unsprung weight? Look at the mass of that 1-1/4" vented brake rotor? That I do not understand considering the puny size of those motorcycle rear calipers? What's that about?
quote:Originally posted by Husker:quote:Originally posted by PanteraDoug:
That is probably the e-brake.
