That would translate to 22 mm for the front disc… 19mm being minimum then I would go for 20 mm in the back..
I cannot find anybody who can reproduce the brake discs for a reasonable amount without making 10,000 of them…
i’m going to try another way… and unless somebody found already a substitute that fits the 15 inch wheels
On my all-Wilwood braking system (front and back), I used Porsche 911 (early version with 15" wheels). They fit stock AND Wilwood calipers, but need a thick aluminum spacer/adapter to bolt on. The rear discs also need lathe machining to fit the Pantera uprights and axle flanges. The ODs match the Pantera discs, too. Larry Stock at PanteraParts.com sells these.
@LeMans850i posted:I cannot find anybody who can reproduce the brake discs for a reasonable amount without making 10,000 of them…
You need to go into the current race car circuit. There you will find existing companies that will make any rotor for you.
How much do they cost? Don't ask but they are still less expensive then you can do yourself presuming that you put a value on your own labor time.
I will say that because the original Pantera rotors are solid, you really can cut them past the original posted minimums. That is for most street use and if you are doing a lot of "open tracks" events, you need to go to a system that is easier and more economical to replace at the track on track day.
The rotors themselves generally are ok to over cut but at some point there is a safety factor for limiting the amount of travel that the caliper pistons should be used to. That is affected by the thickness of the rotor.
The original Pantera is just a hybrid of so many parts, including the brakes and I seriously doubt there was any consideration to the car existing 50 years into the future?
I personally have seen experienced "Vintage Racers" go through two or three rotors and pads IN PRACTICE before the race even starts.
At the time that came to $100-150 per corner so it gets a bit pricey just on brakes, not even counting the tires so it isn't as simple as just driving the car to the track, running it, and then driving it home.
You need a plan first and that includes all of the above considerations.
There aren't any vendors that can sell replacement rotors to you at $30 each that don't originate in Taiwan. They are modifications of another application
Lemans, I meant to congratulate you on your front brake hose restraints- very neat. For those who don't realize, those dot-3 stainless braid hoses move around a lot during driving, and the stainless braid is quite a bit harder than magnesium wheels. One club member had his machine a groove in one wheel- which is only 0.185" section thickness. It was deep enough to cause that wheel to be scrapped. And if you go with stock rubber, the spinning wheel will wear away the rubber hose..... Tie the darn things down!
Lemans, can I trouble you for the model number of your front calipers ? They look like the Dynapro 6A s and I know they are handed. The piston diameter would be enough to determine it if you know that .
Also was there a model reference on the lug mount adaptor ?
Thankyou
At the risk of being crushed by the forums collective knowledge and opinions, of which there are many ,I did have a look at the front rotor question with respect to current Wilwood products.
The best Hat option would appear to be
The PCD , Hub center and offset appear to be spot on. The application note says this is a Pantera specific part. It is similar to the blank hat but with all the hard machining work done and all the dimensions seem to line up .I could not find the face thickness to check that dimension, but we should be grateful Wilwood are offering this product.
Remember you only have to buy the hats once !
Rotor options are available in either 0.81( 3 off) or 1.25 inches ( 2off ) .
Here are the 0.81 inch by 12.2 inch rotor options to match this hat:
Here are the 1.25 inch by 12.2 inch rotor options:
The four piston FSLI Symmetrical Caliper dimensions look like they will go on these rotor widths and still fit in a 15 inch standard rim.
The 12.2 rotors are 6.1 inch radius plus the caliper clearance gives a 6.85 outside clearance requirement without andy gap.
The inside surface of the std 15 inch rim at my best measurement 14.35 inches giving a radius of 7.18 inches. Anyone else with another measurement on the inner diameter please speak up.
This should give just enough clearance ( around 5/16") for the occasional adhesive wheel weight to go rocketing past.
You can get these to suit both rotor widths
0.81inch width with a 1.25 inch diameter pistons
1.25 inch with 1.38 inch diameter pistons
I did have a look at the six piston dynapro options :
At an outside radius of 6.97 inches on the 12.2 inch rotor you only have around 0.2 or 3/16 of an inch. Not enough for any wheel weight clearance and getting pretty close to the nelly, but a miss is a mile!
These are all straight off the shelf - no machining required.
Lemans will probably let us know down the track !
Cheers.
Just for a fun comparison here is a four piston Dynpro caliper mounted on an oversized 12.6 inch rotor sitting inside a 15 inch rim.
Still fits but only just . Wheel weights would likely be toast and jam depending on where they were mounted.
I think the 12.2 inch rotors that match the Pantera hat as offered by Wilwood would clear just fine and would be a perfect choice dimensionally.
@Percy I will see what I can find… I still have the original boxes, but I do not know if their part number is on it
Thanks Lemans!
