So for the last about 9 years I have had Michelin Pilot Sport PS2s, 245/40ZR17 fronts, 335/35ZR17 rears.  I can't remember my rim widths off the top of my head but probably something like 11 and 13.  Rears are still available, the problem is the fronts.  The only current (street/sport) combo of those sizes by the same mfr in the same tire model and compound is now Pirelli P Zero Asimmetrico.  Which I guess is ok, though it's also pretty pricey and seems to have mixed reviews.  I was hoping to either find more of the same Michelin, or a matched set of Kumho or maybe Nitto, etc., but those are no longer made in that size combination.  I can wait a bit before my "10 year" tire window is up, but I need to continue on some path here.  Obviously, mis-matching tire models and/or brands opens up an array of options, but the manufacturers do not recommend that.  Thoughts appreciated.
I had a front wear out from a bad ball joint, so I replaced both fronts. Like you I couldn't get ps2's so I ended up with Pilot Super Sports 225/45/17. The tread pattern and tire was very similar to the old ps2 and they were nearly indistinguishable from what I pulled off. I still have the old 335/35/17 on the back.  Check if you can have a look at those in the size you want or possibly newer PS4's for the front and then compare them with the tread on your rears. If you switch to a 315/35/17 rear you might be able to find a true matching set, but I think that may have changed now as well.
I believe PS4's come in the front size you want but I have not seen them side by side to see how they compare to a ps2.
Yeah, I actually chatted with a person on tirerack asking that very question earlier, and of course he gave the standard response that the manufacturers don't recommend a mismatch in tire model, but it's good to hear from someone who has done it (not exactly, but similar).  And I think I tried the 315 route, I'm not set in stone on 335s, though they do bring many comments lol.
Great suggestions, guys, thanks.  I had also considered 255 for front, I just feared they might scrub, but time will tell.  275 would of course be more likely to scrub, but 255 wouldn't be too much of a stretch from where I am now.  275s even sound tempting, though turning them in a parking lot without power steering, I could see being a challenge.
Well if you want the true GT5 experience go with the 275's I also have upgraded upper a-arms with 7.5 degrees caster to help tram lining at speed. Tire scrub depends on your wheel offset, mine were made to original GT specs, although I can get a slight tire rub on one side at full lock.
I missed the part where your tires are 9 years old! 6 years is the recommend maximum and most shops won't even handle anything over that age now for liability.
