I just installed a new shift linkage and I was wondering if anyone had detailed instructions to set the adjustments. There has to be a simple way to install, index neutral and set up the action like they did on the production line.
I didn't have any issues with the old one except someone noticed a slight bend in it when I took it out to upgrade my oil pan. I was advised to upgrade it to the one I have now which looks great and should work well once its adjusted. Unfortunately, I haven't been able to find any installation or adjustment procedures.
I guess a basic explanation as to how the shift linkage works would help for starters. I got the shifter to go all the gears except reverse and then I made a slight adjustment and I lost all my settings again.
There has to be logical procedure to follow. Most of the posts I've read make it sound like some sort of voodoo and magic is involved with a little mojo mixed in... which I'm starting to believe.
  • image1
Not mine, but may be of use? - Are you talking about the linkage that runs from the shifter box, through the trunion bearing thought the firewall, through the tunnel to the shifter lever?
If so, the is no real adjustment specs to speak of. The way I set mine up was up is by hooking everything up without tightening everything yet. Also loosen the turn buckle on the linkage and the trunion bearing. Have someone hold the shifter lever centred in the gate and tighten down the turn buckle on the linkage. This sets your left to right centre position. Then tap the shifter linkage buckle forward or back until it also sits centre in the shifter gate. This sets your forward & back centre position. Then tighten down the buckle. Shift it a few times and see where the trunion bearing wants to sit. Tighten it up making sure you clear your fender well and the bell housing when shifting to all gears. There's not a lot of clearance so check it after tighten it down. You may have to adjust the trunion bearing up or down a little.
Some very small final adjustments may have to be made with the splined buckle forward or back depending on how you’re engaging gears.
I have you’re solution. I just purchased a pristine 72 Pantera out of an Amish barn in northern Indiana where it had sat under hay for many years! I just drove the car to my home in Tampa (1000 miles; 14 hours) and encountered the first gear problem. You’re analysis is correct, sometimes it stays in third even though the lever is in first. Easy solution. When you want to go to first, bring the lever to the neutral position and tap it to the left as far as it will go. Do this twice and then move the lever to first. Bingo. It worked great with my car. Hope this helps. Mike Sankey
I have painstakingly adjusted the shift linkage per the usual procedure. It's absolutely centred fore and aft in the gate. I have it centred side to side and absolutely inline with 2nd and 3rd slots in the gate. I have experimented at what seems to be all point around neutrally centred.
Is the clutch arm (where the slave pushrod connects) close to vertical or leaning slightly forward? If it is leaning aft of vertical, you may be able to rotate it one spline forward.
...Read this very carefully! I had the same problem with a Second Pantera I sold a few years back! I was always 'Fighting' to get it into Reverse and First. It was a simple problem that the 'Back-Up Indicator Light', SWITCH was screwed ALL THE WAY IN; preventing the 'Cross-Shaft', with-in the 'Small Shifter Box'(the one Mounted on the Left Rear of the ZF) From Sliding TO THE LEFT.
Before you pull everything apart to check the clutch, First, BACK/UNSCREW the Switch OUT and give the Shifter One more try! You Might Be Lucky There!
Be sure to pop the ashtray out and check that knuckle. That one has come loose a couple of times on me.
Although it is not the cure for your specific problem, you need to change your clutch fluid. The fluid same as brake fluid will absorb moisture over time. Next, is rusting in the cylinder bores and eventual seal failure.
I neglected mine for years and paid the price when the master failed with no warning. Flushing is easy with a brake bleeder. I now change the fluid out annually.
I suggest that you stabilize the length of the shifter mech first; centre the shifter lever in the gate per the manual and if the length requires adjustment it should done with the rod length adjuster which is just in front of the swivel joints @ the Transaxle.
I adjust mine by first putting the trans in neutral, put the shifter in neutral, loosen the turnbuckle, carefully wedge small pieces of wood between the shift lever and the shift plate(it has to be centred front to back AND side to side),then tighten the turnbuckle. It may not be the most scientific way but it works like a charm. I’ve tried to have someone hold it in the centre but that doesn’t work very well. It sounds like your pretty close.
I just put my transaxle back in this weekend. Adjustment is a bit tricky. I had to do it twice because when I came home the turn buckle lossened up. When I could not get mine into reverse, it was not adjusted over far enough. I had to get 4/5 as close to the right as I could before it would go over to the left for reverse. Once set it was fine though.
It's really easy once you've done it a few times.
You know that the linkage is adjusted by use of the turnbuckle, which has one right-hand and one left-hand thread (the nuts on the left-hand thread have an indentation marked in each corner).
With the gearbox in neutral, the shift lever should be in the middle of the fore-aft range between 2nd and 3rd gear. If it needs to move forward, or back, loosen both locknuts on the turnbuckle, then turn it in whichever direction is required to get the proper fore-aft center position.
Once that is done, tighten ONE of the locknuts. The shift lever will flop side to side without turning the rod aft of the turnbuckle. I usually pull the lever back into 3rd gear, and hold it centered in the gate (or perhaps just displaced slightly towards the driver) while somebody else tightens the nut. If I'm by myself, I'll fabricate shims to go between the fingers of the gate and the shift lever, to hold it centered while I tighten the nut.
Then, test it out. It should go into reverse/first, and also 4th/5th. It may be displaced too much to one side or the other, so it's a trial and error process. But you'll get it eventually. :>)
I had a similar problem, I think. Mine was shifting fine one day and then the next I could not get third or fifth gears. I played with it and looked at the linkage. The U-joint or whatever you call it near the tranny had loosened and had pulled out some. I did not notice this at first and tried adjusting it a bit and ended up with the rod and the u-joint out of wack. I finally got the u-joint set correctly and then could not get reverse. I had to play with the someone holding the shifter in the middle and adjusting it, then holding it a bit off center. I finally got it right and it shifts fine now. Hope this helps, if you can understand my description.
Removing the little 'plunger' will not cause any problems. I would suspect that one of your three UJ's is not gripping it's splined shaft tight enough. I suggest you check all three. There are two bolts on each. These need to be very tight. The first one is under your centre console. You can just about access this though your ash tray hole. The other two are visible in the engine compartment. You will need a long 13mm spanner to get enough leverage to get them really tight. I had one on my car that kept slipping, no matter how tight I did up the bolt. In the end I got over this by putting molly grease on the bolt threads, this allowed the nut to go that much tighter. It never slipped again.
Once you have eliminated any slipping in the for and aft movement, you now have to check the adjuster turn buckle. If this is not tight, it will allow torsional slipping (left to right in the gate)
Now to make the final adjustment. Put the transaxle into neutral position and loosen the turn buckle. The nut with the notches cut out of the corners is a left hand thread. With the turn buckle loose, get a friend to hold the stick in centre of the gate, and tighten it off. Try the gears, there should be an even gap between the stick and the gate (for and aft) when in 2nd and 3rd. If not, loosen the turn buckle and wind the gear stick forward or back a little until you are happy with the for and aft movement. Now check to see if you can get reverse and 5th. If not, loosen the buckle again and move the stick a tiny bit t the left or right, and tighten it off. Keep doing this until it is right. I have only ever done this on my own, but I am sure it would be easier with help.
Don't forget to oil the UJ's and lubricate the shaft with anti seize grease where it passes through the trunnion bearing (under the left hand header).
If all of these are clearly not slipping as the linkage is moved, you will have to adjust the shaft which goes into the shifter box. If it comes to that, I will step you through that also. Best thing to do with shifter linkage is to do the easiest things first
1,3 & 5 means the shift mechanism back at the tranny is not being pulled out far enough, the linkage needs to be shortened up.
Pantera Parts Suppliers
  Pantera East    Pantera Parts  Marino Perna
  Hall Pantera   Pantera Parts
  Pantera Performance  Pantera Parts
  RBT Transmissions   Transaxles  Lloyd Butfoy
  PI Motorsports   Pantera Store
  Precision ProFormance  Pantera Parts
  Future Auto   Pat Mical
  Lance Nist   Pantera Specialist
  Steve Wilkinson  Panteras & Parts
  Pantera Parts Connection   Larry Stock   1-800-detomaso
  Jon Haas Pantera Electronics
There is another adjustment besides centering the lever in the
cockpit. The shifter shafts can be adjusted by removing a small
plate on the right rear of the ZF case. Behind the plate are two
grub screws that can be loosened and tightened to reposition the
shifter shafts internally.
I had a similar problem on my 72. Turns out, the big trim panel behind the seats would press down on the rear part of the console making it just slightly touch the shifter shaft. After some slight cutting of the trim panel where it meets the console and a small block of wood cut to the right thickness inserted under the rear of the console, all is good. Try pushing down on the back part of the console to see if that changes the shifter operation.
Well, I solved the issue yesterday, and like the ZF ring gears bolts, it involves a bolt that backed itself out and caused interference.
The little box on the side of the ZF, the selector housing, is held to the ZF case by four bolts: three to the rear gearbox cover and one to the larger gear housing.
The single bolt to the gear housing had backed out and was blocking the selector arm (the piece that encircles the greased ball) from sliding to the three forward position gears. It is a round, allen headed bolt and of course, it is blocked about 10% by the operating shaft. But a ball end allen key seemed to do the trick and I hope it will stay out of the way for another 25K miles.
I've thought of drilling and tapping a small hole (for a set screw) in the tubular boss that spaces the box off the gear housing as the bolt is a single and doesn't lend itself to safety wiring like the ring gear bolts.
Q Over the years my cover rear trans cover( visible from rear) has been painted,undercoated and oversprayed. Is this removable for cleaning without springs and things flying?
A It can be tricky, you have one spring for the reverse detent and the shims for the pinion and input shafts,but the main problem is in the reverse idler shaft,sometimes it will stick in the rear cover when removing and that will cause the idler gear to fall in the case,then the ZF needs to be split to repair.
I have had trouble with my gear selection after an engine removal, I set it up initially using the service bulletin Number 2 article 14.
All went well and then fell apart, a couple of splines weren't tight enough as you have pointed out, since then I am having Master cyl problems so cannot finish the job until I fix it.
But your suggestions on adjustment are just the job and I will go back and follow your advice to get it sorted properly thanks very much for your comprehensive post, brilliant.
Ok. I had to psych myself up to attempt this. But anyway I tried to follow the instructions but I just got more confused. I'm no mechanic. So basically I cleaned all the splines of paint and removed as many of the burs as I could. I was hoping this would allow the spline lock so slide easier. I had to lube and realign the rubber boot to prevent it from binding. It was pointing in one direction when I removed it. I set the trunion nut high enough so it would clear the axle half shaft. I also lubed the trunion and set it an angle that the rod moved freely. I loosened all the nuts on the spline locks and lubed the u-joints.
I removed the cover from the gear shifter selector housing on the transaxle so I could see the position of the selector arm. Plus I backed out the reverse light switch but I'll reset it when I put it back on.
I built a gear selector plate to put over the shifter knob and cut a hole out to hold neutral. I didn't have anyone to help he so I had to improvise.
I set the throw length and tightened the spline locks and made sure the U-joint didn't strike the wheel well and none of shifter rod ends bottomed out on the inside of the u-joints when I shifted.
Then I marked the trunion with a couple of reference points and undid the nuts. I worked out which direction the trunion had to move to align the gates of the gears on the shifter plate and then set it.
The adjustments didn't seem to make sense at first. Small movements caused me to lose reverse or 4th and 5th. Eventually I just made sure I threw it in 2nd and 3rd before setting the shifter knob in the central position and gently tightened the trunion and made sure nothing moved. It took about 8 attempts but its set perfectly now.
I think I got lucky in the end. You're still going to need you work your mojo,because there is no logic to the system and I'm convinced there was some serious voodoo going on when they designed the setup all those years ago.
  • image3
Another thing that works (at least in the U.S) is to replace all the gr-5 metric u-joint squeeze-bolts with gr-8 aircraft bolts (or ARP) in approximately the same OD. Used with elastomeric lock-nuts, you can tighten them significantly tighter than the stockers- which will elongate and break if tightened too much.
I was able to get enough adjustment in shift rod length by sliding the rearmost u-joint back & forth on it's splined shaft, to allow the entire powertrain to move backwards by 3/4". I've never been able to break free the length-adjusting coupling nuts with the ZF in place!
I had one '73 in that could NOT be adjusted to get all the gears. Turned out there was sufficient wear in the gear selection assembly under the console to allow some sloppiness. I found it by leaving off the shift gate- then the ZF shifed normally. So I used a grinder to put a bevel on the bottom side of the shift gate slots to match the angle of the shift stick. That allowed normal shifting and a stock look- to the casual eye anyway. The eventual fix would be to replace the bushings inside the stick assembly, but my simple fix is still working after 10 yrs.
I think that was the key when I set up mine. I took a level to the shaft and the car. My trunion is a bit of a pig to adjust so I thought it only made sense to keep it as level as possible to ensure smooth movement of the shaft. I'd probably be still messing around with it if I hadn't of done that. I wasn't aware of the TSB.
When I did mine I adjusted the trunion to keep the front and rear halves on as close to the same plane when viewed from the side as possible. I believe that is what is meant by "parallel". The rods will not be level but rather as close to a straight line as possible between the furthest most points of connection.
Steve
One thing that has not been mentioned here is the "play" in the in the console shifter mechanism that can build up over time. Back ~2001 when I was getting ZONKEY back together I found that, after I put the shifter gate plate back on, I could get reverse or 5th gear but not both. It may have been due to the slightly different geometry due to my 4.6L Cobra conversion or the PPC stainless shifter rod that uses a spherical rod end as the "SHIFT ROD CENTER SUPPORT" (which had a very small amount of free play). Anyway, Wilkinson had a "kit" at the time that replaced parts 18 and 19 (http://www.panterasbywilkinson.com/2016/ill10a.html) in this diagram. It completely solved the problem. BTW, ZONKEY had about 100K on the clock at the time.
JFB,
Yes. I made the long rod parallel level with the ground, but the car was also level to the ground on the jack stand. I also replaced the long shaft rod with an upgraded straight chromolly unit. The old one had a bend in it. I don't if I bent it taking it out or it has always that way. But I was told a bend was not optimal and would make it difficult if not impossible ti get to line up properly.
Also when I installed it, all the adjustments I made with the turn buckle were ridiculous minute. I only adjusted one side of the buckle. They suggest having an assistance when doing it. That's probably a good idea mostly not only to hold things steady when you're tightening things up but also so have a second set of eyes to see how things are moving when you make your adjustments.
I had to walk away from it several times and give it a week to think through before I got it in the end. I don't want to confuse or scare you but it can be extremely frustrating to set. Once you work out how it adjusts best for your vehicle, you'll probably be able to set it again with no difficulty. I just read as much as I could about setting it and took the information that I found applicable to my situation. Then I tried several different strategies before realizing what was working and why other adjustments weren't. But as others are advising, look at every individual component to see if you can detect it anything is slightly off.
I know it would probably help if someone made a Youtube video of how to set it. Unfortunately, I'm not a mechanic and wouldn't be able to provide the technical details. I have to do a lot reading up when it comes to things like this and do things by trial and error. It can be humbling that's for sure.
Originally posted by MX144:...all the adjustments I made with the turn buckle were ridiculous minute...
You did mean a sixtieth of a degree
I wonder why some one has not made an adjustable vernier coupling that could be installed at the ZF shifter shaft. and maybe even give it a scale face so one could see the adjustments being made.
not sure the shift pattern I have at the bottom is correct for the 25-2 ZF, but it shows how small the degrees of rotation are needed to shift
  • adjustable_vernier_coupling
