What kind of grease is recommended for the ball on the shift selector rod located inside the console? I have seen references to white lithium, PTFE, moly and synthetics. What do most owners use?
When my ZF came back from Butfoy I found the grease he used was just a standard amber grease. Did not look like anything special. That is a sealed box, no dust intrusion; I suspect the grease will remain functional for quite some time.
Thanks guys. I was talking about the box in the console, but the selector box on the transaxle would probably have been my next question. Thanks again!
