My clutch pedal sometimes sinks to the floor like there's nothing connected to it. A couple of quick pumps will get the pressure back, but it's happening more frequently and arbitrarily. I bled the system and it felt good as new for a day or two, then it started happening again. There are no leaks in the system and no loss of fluid. I bled it again, thereby replacing all the old fluid with the same results.
Any ideas? Is it time to give my slave cylinder last rights and a decent burial at sea? (Or at least rebuild it?) Any suggestions would be appreciated. Thanks.
Michael
I've had this myself, though not on a Pantera.
The cause of the trouble was the spring inside the master cylinder that is meant to return the piston to the start position. The spring had broken, so sometimes the piston returned and the clutch would work. Sometimes it stuck 'down' so that when I pushed the pedal it wasn't doing anything.
Dirt inside the master cylinder could also cause this, either by making the piston stick or by getting under the edge of the piston seal and letting the fluid pass it by.
Hope this helps.
Michael,
Sounds like your master has a bad piston cup and is internally bypassing. I had this happen to me when I rebuilt the internal hydraulic throwout (Quella's) to fix it's bad, leaking quad seal ring. With that fixed, I still had no clutch movement!!?? Pulled and rebuilt the CNC master --- didn't LOOK bad --- and all has been fine since. You can rebuild MC and slave --- some say not worth the effort and of questionable results --- or buy aftermarket. Do NOT go with the internal hydraulic throw out, as it is a bear to adjust and requires full ZF removal to do so. Stainless long throw slave --- think Pantera East is cheapest on this --- would be best at the back end. Stock style and aftermarket --- CNC has a nice aluminum unit, call Quella --- masters are available from the vendors.
Good luck, Larry
Thanks Rapier and Larry,
It makes sense what you both say.
One more observation was that when the pedal was 'floppy' when depressed, the slave did not move. As the pedal was pumped, the slave would move little by little and when full pressure would return, the slave had it's full travel. Is this indicative of the MC being bad, as both of you suspect?
Larry,
Thanks for the benefit of your experience regarding the hydraulic throw out bearing. I wanted to find out more about it for possible future installation. I didn't think it would be that much trouble!
Michael
Yup. I had the same problem with my BRAKES (much scarier!). After rebuilding calipers, installing SS lines, I finally determined that the master was bypassing. Replaced it with Pantera East "later model" Ford unit with adapter. Now I have REAL (as good as you can get with stock calipers) brakes. Don't bother rebuilding the clutch master. Do it one shot, save yourself the aggravation. Maybe Marino can give you a break if you buy the master AND slave from him. While you're at it, if you still have that cheesy plastic line going to your slave, replace that with SS. It's $79 well spent. Me? Mine blew unexpectedly spewing brake fluid all over my FINISHED engine compartment!
That makes since Deeb. I recently went through the problem of my intake manifold gasket going south and leaking oil into the intake ports. This casued my oil to run hot, which casue my motor to run hot. I recently checked my clutch fluid and it showed discoloration with what appears to be from getting hot. Fixed the instake problem. Flushed the clutch fluid and it's now back to normal fluid wise.
A "floppy" pedal fits with a sticky master cylinder. The exact thing happened on my Sunbeam Rapier (called "Alpine GT" in the USA). For most of the stroke of the clutch pedal all you are doing is pushing against a spring, only the last quarter inch of movement does anything. If you keep pumping, the master cylinder piston will sometimes gradually move back and the clutch will work, but not for long.
I say take the master apart to find out what's wrong, if it looks at all damaged or worn buy a new one. A new one is a better bet than a repair (I've been there a few times!).
