I know this topic has already been addressed multiple times, but most of the posts are quite old and I am looking for the latest developments on what is the best gear reduction, high torque, heat resistant starter on the market for Panteras.
When cold, she fires right up. When hot, she won't turn over.
I have the Pre-L high compression, closed chamber motor.
I've already wrapped the starter, run a thick new ground directly from the battery, and backed off the initial advance from 17 degrees to 10, which is what is specified on the engine data plate.
Any suggestions would be greatly appreciated.
