My 74 Pantera appears to have a 3 guage battery cable between the starter relay and the starter, which seems a bit oversized. Is this the correct size?
IMHO, if the battery is far away from the starter, the bigger the better! And use braided copper, not solid wire. On one of mine, I used 0-gauge arc welding cable to reduce the voltage drop.
