A friends 74 has had someone but the incorrect size blades into the stock arms and they are two long and of course hit each other on each pass.The original blades I believe should be 15" and was curious if the actual rubber blade insert could be inserted into the the original blade assy? When they were available from the manufacture could just the rubber insert be replaced or did the complete blade assy. need be replaced?
