there is a threaded hole on the front face of the block located immediately below the thermostat housing, above the water pump, on the timing chain cover surface
That's the spot! I moved my temp sender there last month:
http://www.banzairunnerpantera.com/updates_thermostat.htmAlso, install a drain petcock in the expansion tank where the thermostat used to be. It will allow you to drain only the top half of the cooling system for future themostat changes.
Ciao!
Garth
