After today, I guess you REALLY couldn't call me PanterHunter any more - but I like the name, so I'll keep it anyway.
I am now the proud owner of Pantera THPNMY04713!
Specs:
1972 DeTomaso Pantera - THPNMY04713 - Ferrari Red
Bare Metal Restoration
BODY:
Bumpers Removed
Battery Dropped
Floor Pans Dropped
Billet Hood Vents
Powder Coated Trim
Smoothed And Welded Engine Compartment Painted Body Color
Brakes:
Wilwood Vented Rotors
Aluminum Calipers And Hats
Stainless Brake Lines
New Hard Lines
AC:
Rotary Compressor
New AC Lines
New Evaporator
New Oversize Condensor
3 Speed Blower Motor Setup
Stainless Shroud
Engine Compartment:
Body Color Engine
Stainless Steel 1 Piece Firewall
All Wiring Hidden
Aluminum Camber Bar
Stainless Steel Water Bottles
Stainless Steel Water Lines Engine And Under Car
Stainless Steel Vacuum Line For Brakes
Lay Down Radiator With Two Meriah Sucker Fans
Thermostatically Controlled
Suspension:
Extended Upper A-Arms
Polturethane Bushings
Rebuilt Uprights
New Lower Pivot Bolts With Zerks
1 Inch Sway Bar With Aluminum Brackets
Aluminum Control Arm Covers
Group 4 Springs And Adjustable Shocks
Transaxle:
Side Covers Powder Coated
All Stainless Hardware
Safety Wired Differential
New Clutch Master Cylinder
New Clutch Slave Cylinder
New Clutch
Interior:
Late Dash With Late vents
Custom Console With Horizontal Gauges
Alpine CD Player
New Seats
4 Point TRW Seatbelts
Engine:
Boiled Block
.30 Over TRW Pistons
Chrome Moly Rings
New Rods, Mains, Timing Chain, And Gears
Crane Cam, Roller Rockers, Screw-In Studs
Guide Plates, hardened 3/8 Pushrods
Stainless Steel Valves
Mallory Electronic Ignition And Coil
Hi-Flow Aluminum Water Pump
High Torque Starter, GM 1 Wire Alternator
Polished Holley Carb
Polished Edelbrock Performer Intake
Polished DeTomaso BValve Covers
Braided Stainless Steel Lines
All new hoses And Belts
New Alternator Idler Pulley
Compomotive 8" And 11" Wheels
Pirelli P7 Tires
Has All Original Parts, Books And Manuals
