if you have a pantera clutch in. Can the Throwouyt Bearing still touch the fingers a little? If so, Why would it?
quote:Originally posted by webbers:
I put a new throw out bearing in and a new clutch. The problem I now have and did not have before is, When I step on the gas, It will drive normal and get up to speed. But, Anytime I step on the gas a lot more the engine just spins. Should I have also changed the pressure plate? It ran before the change.
quote:Originally posted by Peter Fenlon:quote:Originally posted by webbers:
http://www.panteraplace.com/page124.htm
I have a 3 Finger Clutch. What ring? It`s one piece.
