I just picked up my "new" pantera at the harbor yesterday party
My turn signal is not working but hazard light is working (although the botton are probably broken, as it will not stay in) is it different relays for hazard/turn signal?
There are some lose wires in the pictures. Anyone who can see if they are related to the turn signal. (or at least tell me which one is the relay for the turn signal)
What year is your car?
I think both round cylinders are "buzzers" for seat belt and ignition key. Somebody probably removed the wire to stop the noise.
On my car (1972) A rectangular relay with 4 wires controls the turn signal. But it works with the 4-way flasher too, so if the flashers are working, I don't think you have a relay problem. I do show separate fuses for turn signals and hazard. So maybe a blown fuse. On my car the turn signal and brake lights are on the same fuse. Do your brake lights work?
I had the same problem with #6287. The hazard light switch was broken, and needed rebuilding/adjustment.
Se http://www.banzairunnerpantera.com/updates_hazardswitch.htm
