under the front bonnet (hood) on my 3840, is a black almost felt like material, its still attached under the car chassis plate so I assume its the original stuff. Its coming adrift after so many years, so it needs to be renewed. are original kits for the stowage compartment available? and ditto question for the rear fibreglass tub, this is also covered in the same kind of black felt, but looks pretty amateur and none factory. I do like the diamond patterned stuff some people fit under the rear Hood, what material is this, a llm help appreciated thank you.
