This is on my Pantera project that I received in February.  The engine is rebuilt, mostly assembled, the heads are installed, and it has not been fired.  The intake valve in cylinder #1 is not seating.  Perhaps there is some debris that is keeping it from sealing.  The engine is out of the car.  I am thinking of pulling the spring and spinning the valve with a drill in an effort to clear any debris that might be in the seat.  All of the other intake valves are sealing.  Any ideas and insight that you have about this is appreciated.
  • mceclip0
I made a valve removal tool out of a pry bar and was able to get the retainers and spring out.  Next, I spun the valve with a drill, and then reassembled the spring and retainers.  I then pressure tested and vacuum tested the intake runner and found that both values improved.  This is an indicator to me that the valve will likely seat once the engine is running because of the explosions pressing against it.
It looks like I will be moving forward with final engine assembly and installation into the car.
Here is a photo of the tool that I made.
  • mceclip0
Risky business…
I agree with Adam!!!
AND : there are hopefully no explosions in the engine ! … it’s a burn 🔥!
there is also the possibility that the “dirt” , if it’s that , stays in the same position and just gets pounded into the seat on the head or on the valve and it will not get better! Then, you have multiple possibilities of failure!
your problem may even be a not proper installed valve seat… If that’s the case, you are actually lucky that you discovered it before you fired it up!
I would bite the bullet and open it up!
IMG_2437
There can only be two answers:
the valve seats proper
or
it doesn’t!
there is no… almost good!
  • IMG_2437
I am wondering how common this problem is.  It is likely that most of us have sent cylinder heads to a shop for a valve job, installed them upon receiving them, and run the engine that way.  On the contrary, I think few of us have pressure or vacuum tested the cylinder heads after the work was done.  The only reason I did so was to test the plumbing for the EFI's MAP and IAC (Idle Air Control).  While testing that plumbing, I found leakage in the manifold gaskets and fixed such with thick gaskets and sealant.  While continuing the testing I found the leak in one valve seat.  Throughout this testing there have not been any leaks in the plumbing for the MAP and IAC.  I am somewhat reluctant to tear down a sealed manifold and cylinder head just in case one valve might not seat once the engine is running.  I am now setup to test the valve's sealing ability at any point in time.  I am inclined to run it as is, and test the valve's seal after break-in.  Over the years I have become somewhat accomplished at removing Pantera cylinder heads in the car and have a special adapter for my engine crane that handles cylinder heads nicely.  I think I will roll the dice and hope that the valve seals.  If it does not then I will pull the head in the car and lap the valve.
Thank you for your input on this.
Here are photos of the plumbing that I was testing.  It is the black tubing and push to connect fittings.
Images (4)
  • mceclip0
  • mceclip1
  • mceclip2
  • mceclip3
I spoke with Wilkinson about this and I am going to try lapping the valve in place.  I can reach the valve through the intake runner and apply a small amount of lapping compound and spin it with the drill again.  Then try to remove the compound with a paper towel.  The photo is fuzzy but the valve seat is visible and somewhat accessible through the runner.
  • mceclip0
@adam posted:
Lapping compound is a great idea, if you have any crap on or already into the seat just put that compound on and oh heck attach your drill to the valve and spin it.
Low speed, changing rotation, With a 4 inch hose connection between so you can not apply side loads!!
@stevebuchanan I’m glad you to attempt to fix the issue!!! I was surprised that you would let it go…
after you detected and fixed the intake leak so meticulously and then you would let a much worse situation slide…..
Not sure how you keep the lapping compound out of the cylinder..😳
@panteradoug posted:
If by chance there is some type of debris under the valve and you are able to knock it loose, where does it go?
Hopefully not between the piston and the cylinder wall but hope should not be a plan.
I don't understand the apprehension in pulling the head?
Yep… My thinking as well…
Reading about sealing the intake manifold it probably takes  one day to just clean the  sealant off.. Still wouldn’t stop me pulling the head..
And lapping compound is like fine sand in a paste.. and absorbs the metal ground  off…. Rotating will sling the paste… and it will dry and fall in…
IMG_2439
  • IMG_2439
lapping the valve worked.  With a screw driver, I applied a small amount of lapping compound, about half the size of a pea.  I ran the drill at low speed in both directions as Roland suggested.  Then I put a series of paper towels soaked with WD40 between the valve and the seat in an effort to collect debris.  I ran the drill between some of the cleaning cycles.  The valve spun smoothly in its seat at the end.  The combustion chamber is packed with rope through the spark plug hole to hold the valve up and it may have contained some of the debris.  There could not have been much that was causing the problem.  With the spring reinstalled, it now holds a vacuum like the other intake runners.
  • mceclip0
That sounds very good… !!
were you able to see the lapping mark on the valve? Sufficient?
I hope you don’t get me wrong. I’m rooting for you….
I am just allergic to shortcuts because my car was made out of shortcuts ….
i sure you know all the things I did and the 💩 I went through… opening can of worms seems to be my main job since last November when I bought my Pantera…
From pedal box to brakes and brake lines to cooling system to heater and A/c core and fan  to dash and center console with all the electrical problems including headlight motor , window regulators to gas filler to wheels and rusted through heater tubes to brake discs and wheel bearings, headlight switch ordeal and on and on …
I thought it’s a 4 month thing I’m doing here BUT I’m looking a whole year right in the face 😳
I drove my car today for the first since I bought it… 12 miles I did…
I came back with a few things… and the fighting continues…
IMG_2449
  • IMG_2449
Thanks and it’s great that you got your car going. I think that’s the most important thing with Panteras is to have them driving. I love working on them, but it’s most important that they are drivable. Good work.
Thank you 🙏
my car got killed by 1000 shortcuts (I assume as sales prep )and then sitting in a museum for many years..
It will be my daily driver… I will beat it into submission!!!
imagejpeg_0
Resized_20240930_145526
Images (2)
  • imagejpeg_0
  • Resized_20240930_145526
The cylinder head is off and will be going to the machine shop this morning to fix the #1 intake valve and the #4 exhaust valve.  I did another leak down test this morning and the other valves are sealing properly.
This is a high compression engine.  It has 1970 D0AE closed chamber heads and flat top piston making it higher compression than the 1971 Panteras.  The 1971 D1AE closed chamber heads have a higher volume chamber.  Hmmm, maybe I should reduce its compression with the thick head gaskets intended for such?  Or just run 100 octane?
Images (3)
  • mceclip0
  • mceclip1
  • mceclip2
Do you know what compression ratio your set up has? I would try to be able to use 93 pump gas.. ) -10.2 ish- just for ease of operation and if you ever want to sell it you would have limited customers for 100 octane only and it’s a pain in the ass to live with that! …. couple posts ago you said yourself “The most important part is that they  are Drivable” 100 octane only puts a limit on it…
I’m glad you took the head off and fix it properly..
When you get it back put the spark plugs in, flip it over and fill the chambers with gasoline… Just for the fun of it (and “trust but verify”)
I used Summit's calculator and it came in at 9.64.  I don't know if I am doing this correctly.  If 9.64 is correct then 93 octane will work fine.
Compression Ratio :9.64 : 1
Total Displacement (in.3) :357.16
Total Displacement cc's :5855.08
Inputs to Summit's calculator:  Bore 4.030, Stroke 3.5, Volume 62.8 cc,  Piston Dome/Dish 0.0, Deck Clearance .072, Compressed Gasket .033, Cylinders 8
It could be the deck clearance (.072) that is reducing this engine's compression ratio.
And you did not account for the valve relief  either..
You should be fine..
did you meter the 62.8 cc?
Your calculation is close enough. You are about the limit of 92-93 octane in the pumps in the US.
The closed chamber head Clevelands are particularly sensitive to octane. You still may need to limit total timing and more likely the rate of advance but you can't know that until you are up and running.
You do not want any more static compression so use standard thickness head gaskets.
Agree… you should be fine running pump gas 93 Octane.. and play with timing once it’s running as Panteradoug suggested!
and if push comes to shove and you get a little pinging going on when it’s extra hot , you can add octane booster… I had to do that on my 1974 911 Carrera (210hp) I brought from Germany… Worked great!
but I doubt it very much being in the 9s..
IMG_2475
  • IMG_2475
I removed the spring and inspected the valve and the seat, and it looked perfect.  Next I put a thin layer of blueing paste on the valve, pushed it down in the seat, and removed the valve. The paste that transferred to the seat looked perfect as well.  I then cleaned off the blueing, pushed the valve down and filled the chamber with gasoline.  No leaks.  Only the weight of the valve is holding it down.
  • mceclip0
...Were All the Valves Lapped-In By Hand!!! Before Assembling in the Head??
NO Power Drill! IT Influences the alignment and It Wears the Valve Guides, Oblong! It's simply Too Fast! The Guides are Not there for the Valves to be spun in them, only a slight rotation during operation. It is Not as accurate as Lapping by Hand.
If The Valves are already Installed in the  Head, You Disassemble The Valves. Every one and Lap them In, By Hand ONLY, Slow, Reversing and Accurate.
I Did!!  Just use the FINE Grit. Do Them All and Make sure they get back in their matching Bores
...If a Exhaust Valve doesn't seat, You're Burning a Pathway through the Seat! An Explosion is Not going to seat It!
In My Opinion.
MJ
P.S.  In the Above Photo, is That the Decklid Sitting On The Roof?? NOT a Good Idea, Even with Protection, The Weight of it, over Time, will Leave Marks, that can not be Easily Removed! Glad To see you have some protection at the 'Tail'.
The photo with the deck lid on the roof was from the seller.  I was equally concerned.  I have never done that and never will.  Seems like it could fall off.  Can you imagine bumping into it?
Thanks for the lapping recommendation.  I tried to get the head into a machine shop but they are all backlogged and will take a month.  I am going to lap the valves by hand as you suggest.
@LeMans850i posted:
No leak is what it should be with springs installed… you can skip all the vacuum testing and blue paste and whatever…
It has to hold gas…
Roland and Doug,
The leak down test showed an intake valve and an exhaust valve leaking on that head.  Now that the head is on the bench, the gasoline test shows the intake valve sealing and the exhaust valve leaking.  It appears that a leak down test is a more stringent test than the gasoline test.  Have you come across this before where a valve passes the gasoline test and then leaks once installed?
Roland and Doug,
gasoline is usually a good test substance because of very little surface tension… and it easily administered.. when the engine is apart!
… leak down test is usually implemented if you get low results in a compression check.. this gives you the ability to detect where the leak is..
like head gasket into water jacket or neighboring cylinders , valves, piston rings or bores…
there is a % of acceptable leak down, which makes sense obviously for certain discoveries…
I personally stipulate 5% as still pretty good, 10% says to me  start saving money for a rebuild!
10% can still run pretty good as the high pressure is only lasting for a split second but will “inject “ high temp and deposits into areas where they should not be and will accelerate the deterioration..
I wouldn’t drive myself crazy about that subject.. it’s a car engine and not a submarine….  Some minor leaks are okay.. especially with new parts.. rings not sealed…. And so on..
all of the above is just my opinion… others may think differently!
Thanks John.  Should that intake valve's air leak be of concern?  It seems like the gasoline leak test is a good starting point and that every engine build should include a compressed air leak down test once the heads are installed.  Or is this overkill?
See above .. not working anyway and overkill … I think
gasoline leak down is absolutely sufficient!! Lapping the valves provides a surface that seals against gasoline usually and it provides its surface that is not 100% smooth, which is the same idea as the cross hatch on the cylinder wall everything is new and then the wear of the piston rings and the cylinder wall provide a perfect seal! Same holds true with the valve seat and the valve itself!
