Restoman,
How do you inted to use the car? Do you have a particular powerband in mind? I normally recommend 2000 to 6000 rpm.
I'm not sure if IR fuel injection is as finicky about camshaft overlap as Webers, if so, you're out of luck with using an off the shelf grind. Perhaps Dan Jones can bail me out on this one, since he's also building a motor with IR fuel injection.
A good man to order the custom ground cam & kit from will be Mark McKeown of MME Performance. He's an engine builder with a depth of Cleveland experience, and a Mechanical Engineering degree. He will be able to spec out the cam to meet your requirements, and then get it manufactured for you. Everybody gives him high praise for both his business ethics and his products. The telephone number is: (301) 246-9225. He's in Maryland.
http://www.mmeracing.com/about.htmYour friend on the DTBB
