HI,
I've had the car about 2 months and I cannot get any heat to come out of the heater core in the dash. I believe it might be that the heater hoses are not connected correctly to the water pump. One hose is on the pump and the other is on the block. Should they both be on the pump? There is no isolation valve anywhere.
