Not sure exactly what you need, Paul. Do you need a diagram of where the tubes actually go? There's a schematic outline of water flow & the tubes involved shown in Bulletin 10 of the Tech Service Bulletins from Ford. As for mounting the alternator, you will need some type of bracket; either the stock one or the GT5 or -5S type that allows a stock alterrnator to mount above & behind its usual place. The alt. will then be driven off the rearmost sheave of the AC pulley and will allow the so-called "flat firewall" on the passenger side. BOth brackets are available from all the Pantera vendors, or, a good welder could duplicate either bracket in a few hours, probably costing close to what the vendors would charge.
