I want to change the brakes on my 72 Pantera with 17" wheels. I'm looking for everything:
• Master cylinder
• vacuum booster
• discs
• calipers
• pads
• braided hoses
• P-brake
My criteria are:
• Street 600HP worthy, occasional track duty
• Bolt on
• Matched parts, don’t want to have to fiddle with brake balance
• P-brake and all other I can’t remember included
• Light, obviously
• No change to wheel alignment or wheel moved outward to make space for discs
• Cheap
• Since wheels covers brakes, I don't need painted calipers or drilled discs
Any views from anybody that has installed a full kit?
Hi Mikael,
We have been talking about our brake kits for about a month now on here and they should meet all your requirements.
Here is a link to our topic...
http://pantera.infopop.cc/eve/...0045562/m/9671015716
We can make any modifications to the kit that you would desire such as, Vented and Slotted rotors as opposed to Cross-drilled, and what type of calipers you would like.
Our hats are mounted inside the hub, just like stock. Which unlike other brake kits, this won't change your wheel offset at all.
With this kit you will not have to change your brake booster or master cylinder. You will also be able to take out your proportioning valve in the front, as it is not needed.
This kit is also pretty much a bolt on replacement which includes all mounting brackets...
Take care, Chris
http://blog.saccrestorations.net
