Holy cow George. You are probably right. Dang, I keep running in to this all the time. My brakes ain't the same, my anttena is differant, my clock is not lock any of them. I mean I like that about my car and all, but when it comes to giving advice and stuff, I can't be sure of anything because so much is differant on my car.
And what if I have to replace a broken part or something?? I will probably have to have it custom made by some machinist in Lithuania who will take fourty years to make it.
DOH!!!
Originally posted by mikee:
I have a 735 cfm on the shelf and planning to install this soon. What jettings would you recommend on a stock engine?
Originally posted by cuvee:
Dont leave out the older 4150-735cfm, from the 390-428 engines.
Sorry it took so long, I was out of town... My engine is not stock, but I think my carb. had 80/74. The engine runs great but I think its running a little rich? Will try 78/72 when it gets warmer.
Yep Mr. Rapier. The number was 5534. Which I can't find anywhere in any of their literature, both past and present. So if I ever need to get a rebuild kit, I will have to call Holley and beg and plead with them. If I am pathetic enough they may just have me send them the carb for them to rebuild. Or maybe they will just laugh at me and give me a good price on their latest, handiest, dandiest fuel injection system for race cars. Either way, it just proves that owning a Pantera is indeed, an adventure. Smiler
Originally posted by johnk:
The new carb and accessories arrived today. Man, when Holley says the HP carbs are wet tested, they mean it. Carb was wet right out of the box, and good thing I wasn't looking up the pump nozzles when I winged the throttle on the work bench, pumps were still full and the bowls weren't completely drained. Neat carb with alot of nice features right out of the box. We'll see how well it works..
John,
How did this carb work for you? Still happy with it? Did it require a lot of adjustment or changes?
Don't kow how I missed this thread..
This spring I had my Pantera on the dyno to tune the carburetor, and we kept working at it until the mixture was correct for each test scenario. The general trend was to make things leaner. This is the result:
Holley 4778-2 700 cfm double pumper
Primary: jet 65, squirter .028, power valve 6.5, cam 466 (black)
Secondary: jet 76, squirter .028, power valve n/a, cam 466 (black) hole #2
Matching numbers block, 4v heads, Edelbrock manifold, upgraded valve train.
I'm now pleased with the throttle response, and the car no longer smells of gasoline all the time. We also found a few horsepower, with the final result being 335 rwhp. If what I read on another thread here is correct (20% loss through the drivetrain), this is approximately 415 bhp at the flywheel.
It could probably still be made better, but I'm not going to bother, because I'm in on the group buy for the quad Weber IDF manifolds. I'm looking forward to having those on the car.
