How did you cope with the fact that unlike the original radiator, which has 90 DEGREE 1 3/8" dia. tubes entering and exiting the tanks, the Fluidyne has STRAIGHT 1 1/2" tubes?
Eric
Originally posted by jack deryke:
use wide bent-aluminum L-brackets from the 4 corners of the fan shroud to the front of the rad tanks to lightly hold the assembly in place.
To lay it fwd, drill out the spot welds holding the OEM fan mounts up front. Done carefully, they can be returned to stock with a few tack-welds.
[B]There are two kinds of "aluminum radiators"- one kind is all -welded (e.g-Fluidyne, at least in their nationwide ads) and the other kind is partially welded & partially held together with epoxy. These, no surprise, tend to be cheaper.
On the other problems- the Pantera parts vendors contact suppliers and often get exclusive rights to special-edition parts that will fit a Pantera with no trouble. Such trouble-free parts for Panteras may be unavailable from cut-rate discount stores B]
